Exponential Wood Horns (500Hz) for 1.4" compression drivers
FS: Exponential Wood Horns (500Hz) for 1.4" compression drivers
A pair of exponential wood horns made from birch plywood treated with special oil.
Used in two-way speakers with 18 Sound ND1460A drivers, crossed over at 500Hz with LR 4th order filters. I've included measurements with and without a crossover (see last pictures), which proves that the original response of the drivers is not different.
This means that the horns themselves are completely transparent and do not add/subtract anything to/from the music! And most importantly, the quality workmanship and design exclude the typical horn nasal sound!
GIFTS: Flat top stands made specifically for them - check the photos where they sit on the speakers' cabinets.
A few properties:
  • Diameter of the mouth: 57cm (22.5 ")
  • Exit throat: 1.4"
  • Depth of the wood horns (from mouth to throat): 28.5cm / 34.5cm with the drivers /
[comment]
[/comment]
Asking price for the pair: €750
Will be shipped securely via DPD to most European countries, but don't hesitate to ask me about your country.
Contact me here or on email veselin.karavelov@gmail.com
