I am trying to design a half-bridge SE amp with the HIP2101 Gate-Driver with +/- supply.
I need some kind of level shift beacuse of the +/- supply.
Does anyone have an idea or design hint???
Level shift can be done by the use of PNP transistors as it is often done with IR2110 drivers for instance.
You will find several examples on this forum or this one on the web (Q3 BTW):
http://www.irf.com/technical-info/refdesigns/iraudamp1.pdf
Charles
Charles
