Is it ideal to stick an exodus anarchy into a box and use it as a subwoofer?
How good will the sound quality be?
There is plenty of info on the anarchy tapped horn build. There was a flat pack available for purchase as well to construct the horn. Go that route!
http://www.avsforum.com/t/1238398/reed-exodus-anarchy-25hz-tapped-horn
Reed Exodus Anarchy 25hz Tapped Horn
Seconded. I used the TB woofer that was pretty much a drop-in. Loud and low, capable of doing a room of 10m by 20m (away from walls) to decent levels.
Not nightclub levels, sure, but the room was too big for that and the drivers too small.
Chris
