Hallo
for my data book collection I need follow older data book titles about books, that was release between 1975 and 1985:
1) from NEC with jFET's and BjT's both "small signal" (e. g. 2SJ44 and 2SK163) and power devices (e.g. the types, that are to see about http://homepage2.nifty.com/~mhitaste/audiotop/dcamp_parts/dc_ampparts010.html )
I don't find this one by www.necel.com
2) from SONY V-FETs and BjT's also both "Small Signal" and "Power Devices" (e. g.2SJ18/2SK60)
I don't get any advices about http://www.sony.co.jp/~semicon/english/
3) Fujitsu BjT's also both "Small Signal" and "Power Devices"
There are many of these datasheets on the Internet, but unfortunately only from other companies as the developer company.
If I know the exactly title and the year of release of this data books, I can order copies by my tele rent library.
Please let me know, If one of you know about more of this data book titles.
Thank you very much in advance
I have Nec selection guide from 1995 in pdf, you could go through that and see if some of the transistors are in there, I had one from 1985 but I deleted it as those parts were impossible to find. Contact Jacco he is a walking library around here and might have some info.
Try Datasheet archive, in google, I think I got the Nec selection guides from there.
thank you for this advices.
I also have Nec selection guide from 1995 and overview with short form data from 1985. Additional I have a wide range of newer NEC databooks from 1983 and later. But about certainly jFETs and power BjT I haven't original datasheets and books. Especially the aera between 1970 - 1983.
If you try to find datasheet of the good known jFET 2SJ44 and 2SK163 on the web by google, you get a wide range of proposals and short form data from comparable lists and shortform datas, bot nowhere original NEC datasheet.
Therefore I need the exactly titles of older databooks of NEC, SONY and FUJ for order copies by my tele rent library.
in the meantime I have found the data sheet from NEC's P-CH jFET 2SJ44:
Download | Datasheet Archive
http://www2.renesas.com/maps_download/pdf/TC-5409.pdf
http://www2.renesas.com/maps_download/pdf/TC-5466.pdf
But I am looking for the associated NEC databook from 1981
Who know the exactly title or can post a cover image like examples by post #34 and #37 about
http://www.diyaudio.com/forums/parts/167680-vintage-transistors-4.html
And I am still looking to other old databooks (read post #1).
I am still looking to the titles of japanse databook from NEC, Sony and Fujitsu, also Hitachi, Mitsubishi, Shindengen and Matsushita.
Naturally members from Japan can give here at most likely advices.
