EV eliminator into econowave?
So I have a pair of EV eliminators which are the older versions of the speakers seen here.
EV ELIMINATOR-I-E 15in 2-Way Loudspeaker + -  Passive Full Range Speakers- Full Range Speakers- Speakers- Pro Audio- PSSL.com
I have had these speakers for years and although they sound great for PA they are not what I would call audiophile. Now that a lot of work on this website has been done using wave guides and PA drivers I was wondering if anyone here has some ideas on how to make these sound like something I would want to use in a house. They are just sitting in storage and I hate to see them go to waste.
To me it seems like there may only be a few things I could really change. I could swap the drivers or I could upgrade the crossover. I guess I could possibly replace the horn with a waveguide but that might be more trouble then it is worth.
So any ideas?
Hey DJ, good to see you still in the game.
That looks like a waveguide but it is difficult to tell from the pictures. If it is, it isn't the best kind. Can you live with the sound of it or not? If maybe then you may get away with just reworking the crossover and treating the waveguide, otherwise, a better waveguide.
If it was me, and I thought it sounded like it had potential (the drivers are good etc), I'd re-assess the box stuffing, deal with any sharp edges on the front, then I'd decide on the correct crossover frequency and get measuring. Redesigning a crossover is a time consuming task but it has its rewards.
I guess what I'm saying is that this style of speaker has a great deal of potential, and you just need to ensure that all the parts come together as they should.
So any ideas?
Hi DJNUBZ
Saw you here so thought I'd say hello.
I am at the moment trying to make a 'versatile loudspeaker'.
It's a large driver 2 way + waveguide.
There's been quite alot of thought about it from other members
@ the thread - 18" + WAVEGUIDE here at diyAudio.
One thing I would say from experience about this type of speaker and also guitar type speakers is this.
If you change the 1/4" jack socket to some thing decent, with good power handleing capabilities, that MAY be all you need to do.
I use the 'Neutrik Speakon' connectors, they are the best speaker connectors available (and not at rip off 'Hi-Fi' prices either).
You could be totaly amazed that for $5 you just got a stunningly better sounding, more dynamic speaker.
Try it, it's dead easy, and it works.
Cheers
Simon
AllenB yeah I have been out of audio for a while but now I am working in the audio field and I am trying to catch up and really get back into the game. Do you think that a change in waveguide would make a large difference in sound? I have not played around with waveguides at all.
The Space Egg Corp, I have been reading parts of your post on the versatile loudspeaker. I am curious what the final design will be. The EV's I have currently have neutrik connector but I use adapters with them. I may try to add a set of binding posts.
I don't DJ anymore so I can use these speakers for what ever I want. In the end it may be better to just sell them and use the money to make something else. It just seems to me like PA cabs like this are 90% of what a gedlee suma is. I'm surprised guys on this board arn't buying up old PA cabs, building new enclosures, adding a proper waveguide and calling it a day. If I had some wood working tools available, I would even try that.
Without knowing too much about the one you have, I'd still probably consider practicality and economy, which is why I asked you if it was reasonable sounding as it is. You can do things like rounding the mouth into the baffle by adding to it, and you can stuff a horn (much has been written about this).
If you can take some response plots on and off axis you might estimate how good the crossover and waveguide is.
a gedlee suma
If you go down this road, you won't go wrong 😉
gedlee when it comes down to it a speaker is nothing more then an enclosure, drivers and crossover. If you were to take a quality PA speaker, put it in a sealed enclosure, swap the horn for a wave guide and tweak the crossover you would be at a very similar level as your current line of speaker. That still takes a lot of work, measurement and knowledge to reach the level of your speakers but it isn't outside the realm of most people on this board. I believe that is why the econowave became so popular, until the waveguide dried up.
The more I get back into audio the more I think that a lot of designs ignore pro audio drivers to their detriment. Granted the trade off from standard drivers and pro audio drivers is size. It seems like people on this board and other audiophiles are willing to give up a bit of room for better sound.
Hi DJNUBZ
Just pushed the wrong button and posted nothing, sorry...
Yes...Scrap the adaptor, and keep the 'Speakon', unbeatable !
The 'Neutrik Speakon' connector exerts a huge amount of contact pressure compared to the average 4mm, the bayonet fitting means it's self cleaning pretty much, no exposed short circuit prone, oxidizing wiring either.
When I use the Speakons, I double up pairs of poles on a 4 way speakon, and hard solder both the plug & socket.
No nasty melting either, they seem to be made of glass reinforced very heat proof plastic.
Have soldered very thick cables with 2 soldering irons this way.
My opinion is that binding posts are from the dark ages, along with thumb screws and wind up grammophones.
I suppose everyone has to hang up their slipmats and call it a day sometime.
What kinda toonz you spin NUBZ ?
Not sure what a gediee suma is I'll Google it and find out.
It's not from Star Wars is it ?
With the way that listeners habitualy site themselves and aim their bottoms at the dead centre position beween the speakers, there seems to be alot of people wasteing alot of time talking about 'off axis response', at some truly extreme and bizare angles to me.
How do the EV's sound at a sensible living room volume, bum parked between them, not somewhere leftfield or in the next room or back yard.
Cheers
Simon
(sorry about no-post glitch, I have cell phone internet, and this stuff takes ages....later NUBZ....)
I hope I haven't stepped on any toes here mentioning the plug. No harm intended.
Hi AllenB
I don't think you've stepped on anyones toes whatsoever.
In the UK at least, patent and copyright have a direct bearing to what the lawyers call 'punitive gain'.
This effectivley means that any use of copyrighted and patented material by a person who has not sought to make lots of money from it's use, would be laughed out of court, if it ever got there in the first place, which is extremely unlikely.
Private individuals, DIY audioers and amatuer or professional research scientist types are free to tinker with anything they so wish.
Patents are a great way to persuade the easily gullible that a concept is new, revolutionary and a consumer 'must have'.
It's patented, it must be good.
The fact is that there are zillions of sheets of paper with all kind of schemes claiming to be new and revolutionary, gathering dust in patent offices around the world.
A quick rewording by a smart lawyer can generate a new patent, with little more than the payment of a large fee for it's fileing.
Whether it's content is legaly enforceable, or in fact new, or even if the concept works at all, would be for a Judge to decide, clearly with punitive gain in mind.
This excludes all diyAudio'ers from such concerns.
There are few genuinely new ideas out there anyhow, just rethinking of existing ones.
If someone could patent the sheet of toilet paper from the studio john, stuck over the tweeter in the monitors with a piece of bubblegum, then half the recording studios in the world would be in court right now.
As for imorality, that is surely a philisophical or aesthetic question which can only be judged in the mind of a free individual.
I feel privilidged not to be living under communism, or in a overtly represive society, and am free to make these judgements myself.
Cheers
Simon
Well that isn't actually true - its still a violation of the law, not to mention imoral.
Your joking right? There is no law that says I cannot build my own version of anything nor would it be immoral. The law would only come into play if someone were to copy and sell a product you hold the patent for without your consent or licencing. I have no idea where you can even bring morality into this conversation.
Hi AllenB
Thanks for the support T.S.E.C., but it isn't that. Please know that I have no worries with building my own as I have no interest in competing with anyone in business...this is just a hobby for me. Still, Dr Geddes work has done a great deal for me.
I'm reserving judgement until I can work out where he stands here, this has taken me suddenly. But I tend to assume if it's posted on the forum, it's meant to be public unless I'm then informed otherwise, and if I derive from that work I may be inclined to tell people about it.
Hi again AllenB
I think that unless Australia is about to become a Communist or Nazi state you can rest easy.
The Wright brothers flew a few yards in a rinky-dink DIY airplane, if they had a patent on it the Jumbo Jet may not yet exist.
Of course it's meant to be public, the secret-police aren't hiding this under the carpet.
If it's a secret then don't tell people AND expect to make money out of it at the same time.
Cheers
Simon
We're kind of socialist democratic, and we're also pretty cool about a lot of things, like you're mentioning.
Did you know that the Wright brothers actually got the technical knowledge for powered flight from an Australian, Charles Kingsford Smith. Like many scientists, the credit for things tends to get smeared around a bit.
