Send those tubes over here!
We'll soon be getting tax credits for coal power, steam engines and vacuum tubes. Invest in buggy whips while you can get in early (genius climate fix!).
This is global orchestral maneuver, in my country there is no more Tunsgten light bulbs already a few years only leds and fluorecent lamps which reactor emit a strong UV field that is carcinogenic and the blue light quality this lamps emit is very low, very difficult to read a book.They'll be banning incandescent light bulbs next![]()
Ordinary incandescents have disappeared. All you can buy are (ahem) 'rough service' incandescents (which often lack the internal fuse which deals with arcs) and halogen incandescents (which often don't last very long). Soon, compact fluorescents will disappear too. A ban on valves is not something we should treat as a joke, as it is all too likely on the grounds of energy conservation.
Ordinary incandescents have disappeared. .
Wrong..here in Germany filament types are still available at most DIY stores.
The prank April fool idea has a side point...Statistically how many households actually use a tube amp ? My guess, less than 0.001% . Hardly worth anyone getting wound up.
rich
Anyone? Do you mean you?Hardly worth anyone getting wound up.
Perhaps I should have said ordinary incandescents have disappeared in the UK. I was wrong to assume that other EU nations are equally diligent in implementing EU regulations. Or is this another example of the UK gold-plating EU rules?richwalters said:Wrong..here in Germany filament types are still available at most DIY stores.
You may mean 'not worth the politicians banning them'; I fear what could happen is 'good to be seen to do something, and not many people will drop their vote as a consequence'.Hardly worth anyone getting wound up.
Posted 1st of april 2017...
I suspect they are the same 'rough' service' lamps that we have in the UK too (check the box). They are exempt from the EU ruling.Wrong..here in Germany filament types are still available at most DIY stores.
Not wishing to wander too far from the OP's April fool joke I think more thought should be given to the conservation of order. When I listen to my nice warm valve amp in the cold winter evening under the non flickering broad spectrum glow of my incandescent lamp watching the artificial coal effect supplied by another two red coated incandescent bulbs I'm only disturbed by the soft click of the thermostat turning itself off to compensate for my profligacy - bliss.
Ebay Global Shipping Program (GSP) already banned vacuum tubes from the service, completely. GSP is the export agent service that USA-based eBay sellers are strongly encuraged to use. Vacuum tubes are not listed in the "banned items" page yet, but they are sistematically seized and "disposed off" (so they write) by the GSP center as "hazardous items". eBay will refund the buyer and the transaction is removed from the buyer history, the item will be eventually resold domestically by a GSP partner company. This is not an april's fool joke, sadly. Just check any of the eBay support forums or tube-related vlogs (the Guitologist, etc). Last year I still got a few tubes, but on the second half of the year I lost 3 shipments from USA one after another and I stopped using the service. Unfortunately the USPS service costs are a lot higher, and most non-professional USA eBay sellers do not ship low value items abroad. Granted, a few specialized tubes have trace amounts of mercury, but most don't. JJ, as example, does have a EL34 RoHs certificate on the web site. I personally believe that the "hazardous item" GSP ban on vacuum tubes is more related to discuraging the use of the service for fragile items that have unfavorable volume/weight ratio. That's a pity because the service was workig fine (for me, at least).
- Member Areas
- The Lounge
- EU to ban vacuum tubes from 1st January, 2019
