SOLD
For Sale is a Aleph 30+ build in fully working order. Have to sell it due to lack of space for amps in my living room. I have a smaller build of Aleph 30 that i still use, it has the advantage of taking less space / eating less idle power.
Aleph 30+, Dual Mono build, fully tested and working, optimized for current-hungry 4-ohm speakers, soft-start boards included
The Unit for sale comes inside a Modushop 5U / 400 enclosure. I have spent north of 950 Euros in order to build this amp, although @rhthatcher was kind enough to donate Aleph Classic boards and matched semis in order to create the first build of an Aleph 40. I will forward €100,- to Randy if this amp gets sold.
2x 60W into 4Ohm
2x 35W into 8 ohm
Boards: Aleph Classic PCBs, Rectifier and CRC Boards by @rhthatcher
Transformers: 2x Toroidy.pl Audio Grade, shielded, 230V primary, 2x22V secondary
Soft Start board (made in China) and "anti-vandal" switch for each channel
Keratherm heat transfer pads
Rail voltage: 27,6 V
Quiescent Current: 2.7A (adjustable for less idle dissipation)
Heat Dissipation per amplifier channel: 150W
Total power draw: ~ 350W
Heatsink temperature: insanely hot (~60° C)
Sound: insanely good
You can read more about this build if you search the forums for "Aleph30" and limit the results to posts by member "AddiDub".
Some pictures:
2x 60W into 4Ohm
2x 35W into 8 ohm
Some pictures:
Pass DIY Addict
Joined 2000
That's an insanely awesome build at an equally awesome price point - substantially less than the parts cost alone. Obvious love and attention to detail: priceless. Grab this one while it's still available!
I am overwhelmed by all the nice comments on my build. Thank you very much. Indeed I have put a lot of effort in it to make it as perfect as possible.
@ad010685 Sorry to hear that, What kind of physical limitations? The statics of your house? Or your back?
It's not too heavy, only ~22 Kg 😁
The more I think about it the harder it gets to part with this amp 😭 I am thinking about to cripple it down to an Aleph 30 4+4 and put it inside the smaller 4U 300 enclosure. Then just sell some leftover parts.. I am not the best in making decisions..
Addidub, originally was backpain but recently discovered an hernia as well. I Will be under surgery next year, than could do all again. Sell It or keep It as It Is Will be my advise but of course its your call...
Bump 😁
If I didn´t have a custom made XA160.5 collecting dust in my closet.... I would have been tempted....
2 little rascals (2 and 4 years old) and an until now not finished home office room....
Yeah I know... Little bit oversized for office.....
