ET 2 (air bearing) fluid damping trough
I'm redueing an older ET 1 (Eminent Tech) with my own cueing setup and want to add the fluid damping trough. I will be machining my own parts.
The pictures I,ve seen are somewhat vaque, and what I'm looking for is the size of the paddle for the horizontal plane and the viscosity of the silicone fluid used.
If any of you have any info to either question, I would appreciate it greatly.
David
ET's trough manual doesn,t mention the viscosity, only the amount of fluid.
It talks about modifying the paddle to get certain results for specific cartridges, but no stock dimension's. If someone had a picture of the area, that would do nicely
I,ll half to just roll my own on this one.
David
