They claim to have them in stock but this looks like the old specs. My favorite tweeter, overpriced back then but today they are better priced. I have two pair and I would not trade them in for anything, not even for the diamond BS. I like them better then the high end ScanSpeak.
Nominal impedance Zn (Ohm) 8
Force factor BI (Tm) 4.62
Minimum impedance/at freq Zmin (Ohm/Hz) n/a
Reference voltage sensitivity (dB) 91.5
Maximum impedance Zo (Ohm) n/a
Voice coil diameter d (mm) 28
DC resistance Re (Ohm) 5.2
Voice coil length h (mm) 2.8
Voice coil inductance Le (mH) 0.07
Voice coil layers n 2
Resonance frequency fs (Hz) 750
Flux density in gap B (T) n/a
Mechanical Q factor Qms 0.33
Total useful flux (mWb) n/a
Electrical Q factor Qes 0.5
Height of the gap hg (mm) n/a
Total Q factor Qts 0.2
Diameter of magnet dm (mm) n/a
F (Ratio fs/Qts) F (Hz) n/a
Height of magnet hm (mm) n/a
Mechanical resistance Rms (Kg/s) n/a
Weight of magnet (Kg) n/a
Mechanical loss Rm (Ns/m) n/a
Long term power (IEC) (W) 130
Moving mass Mms (g) 0.45
Max linear SPL (rms) (dB/W) n/a
Suspension compliance Cms (mm/N) n/a
Xmax peak (mm) 0.3
Effective cone diameter D (cm) n/a
Nominal power (W) n/a
Effective piston area Sd (cm²) 7.7
Frequency range (Hz) n/a
Equivalent volume Vas (ltrs) n/a
Net weight (kg) 1.6
Stock Code DYDT330
Price CAD$705.49 (Shipping costs and services)
Shipping costs for DYDT330 and up to five similar items:
Within Australia Anywhere else in the world
CAD$10.44 by Australian Air Express
CAD$8.27 by Local Courier Delivery (Melbourne metro only)
CAD$4.35 by Australia Post air mail
CAD$73.95 by UPS door to door trackable
CAD$13.05 by Australia Post air mail
Copyright © 2005 Speakerbits Pty Ltd
http://www.speakerbits.com/Default.aspx?f=box&progress=search&key=esotar
Xmax peak (mm) 0.3
Net weight (kg) 1.6
Stock Code DYDT330
Thanks. However I was looking for the Esotar 2 tweeter specs. The one with they use in for example Special 25 or all the upper echelon models.
I really like the D330 too. One of the best out there.
