ES9018 DUALMONO DAC kit available for pre-orders. The kit will be a fully assembled and tested module with programmed microcontroller, LCD display, IR sensor, remote control, rotary encoder. Buyers can use their own power supply and IV stage. The dualmono dac has isolated i2c interface. Interested buyers can PM for the pricing details. The DAC photos are as follows
I don't see any headers for external Avcc supplies.
Also no provisions for the use of an external master clock.
What level of control does the IR remote supply?
You can have your own hypothesis but this is a tested practical design and works out flawlessly in terms of audio reproduction. This dual mono board sounds much better than a single ES9018 dac. I have made both of them.
Yes, there is no separate headers for AVCC supplies but still you can give external AVCC supplies by removing the four ICs which are meant for providing the AVCC supplies. Also you can desolder the current clock and give your external clock. IR remote controls the entire operation of the DAC, volume level adjustment, filter selection, everything.
have a look at the 'success' of heartwinter's 8741 and 9023 boards and you'll see why this thread isn't a hive of activity like other ES9018 related threads 😉
he also seems to have far more than one (1) thread in the vendor's bazaar.
- Vendor's Bazaar
- ES9018 DUALMONO DAC KIT
