Hi.I am selling some ero kp1832 capacitors.They are known one of the best signal caps around.They are polypropylene film /foil caps.They sound better than mkp caps because they are not metallized. high performance at high frequencies.A very good upgrade for tube amps.Here is the link you can buy from ebay. eBay.ie: ERO KP1832 CAPACITORS FOR AUDIO (BETTER THAN MKP CAPS) (item 180474504999 end time 05-Mar-10 20:35:59 GMT) .Thank you
Hi.Now it is available again.There are different values of Ero kp1832 capacitors.
KP 1832 5% 3600 pF / 1,2 kV 10x32 axial 1,9$
KP 1832 5% 6200 pF / 2,0 kV 9 x32 axial 1,9$
KP 1832 5% 9500 pF / 2,0 kV 11x32 axial 1.9$
KP 1832 2% 0,075 µF / 800 Volt 20x30 axial
ideal replacement for 0,1 µF coupling caps!
Highly recommended! 2,9$
KP 1832 5% 0,39 µF / 200Volt 16x42 axial 2,9$
KP 1832 5% 0,45 µF / 200Volt 16x42 axial 2,9$
KP 1832 5% 0,52 µF / 250Volt 18x42 axial 2,9$
And please pm for any capacitor requirements
Thank you
Thank you
Hi.Why mkt capacitors?KP is the best type.Kp type is better than mkp.Mkp is better than mkt for using on signal path.
Maybe i have it.I should search the storehouse.It can be in somewhere.How many pieces do you need?And which capacitance/voltage?Thanks
Hi.They are really very good capacitors.Not metallized as mkp capacitors and it makes sound better.Many audiophiles like them very much.I sell them in a good price.And they are at limited quantities.Buy before it is too late!Thanks
do you have ERO 1813?
Hi.Yes ero kt1813 is available now.Which values do you need?Thanks
