Equivalent relay available at Mouser?
Coil voltage?
From the specs - coil voltage is 5 VDC
"Signal-relay RY
• Dimensions (LxWxH): 20.2 x 9.8 x 12.5 mm
• Maximum switching voltage: 60 VDC / 120 VAC
• Max switching power: 24 W / 60 VA
• Operate power: 70 - 90 mW
Coil voltage: 5 VDC
• Impedance: 165 Ohm
• Contacts: 2 change-1A
• Washing hard: RT III (IP67)
• Contacts: AgPd / Au
• Certification: UL"
