Enlightened Audio Designs DSP-1000 DAC PCM63K
Perfectly woorking and nice looking dac Enlightened Audio Designs DSP-1000 DAC
It uses 2 pcs PCM63K DACs. it has 3 dig inputs .
Output is little modified because output opamp on left channel has distorted sound and offset on output (it was semi damaged), I change socket to dip8 and now is more friendly to opamp swapping. You can try some other single opamps.
Now are opa134 at output buffer position.
Mute and phase rely are taken out for direct signal path. It is no pops hearing at mute just at turn on little noise.
Price 150€ plus shipping costs
