Enclosure question - active 3way (passive radiator or not?)
Hi All!
it is really hard to get decent passive crossovers [around here] and I found opamps to be very easy to come by... even further... the high quality speakers I've seen around... don't feel very well made and most of the times cost very much!) so... I'm going active 3 way! its not all that more expensive, giving all the advantages of being able to control the speaker much more profoundly...
I'm handy with wood's. I've got tools and some time to spend (on things I like) plus... I'm in to electronics, I'm an electronics technician so I feel comfortable with most of the designs needed for this. I just don't know how to design an amplifier, so I'm buying ESP Elliott Sound Products - The Audio Pages (Main Index) design's 😀
my goal is to have a self contained speaker (all needed electronics inside a back-compartment) receiving the audio (and power-on) signal from the preamp (balanced).
I'm trying to understand if I'll win something by using a passive radiator... in your opinion, will a passive radiator "cause" an interesting improvement in the speaker itself or a "simple" sealed box would do the 'same'?
since I intend to use a subwoofer, (hopefully lower than 80hz) I cant see much of a win on the passive radiator... but I haven't tested properly on any program/forum.
For some of the details I'm also thinking of having 2 compartments in the side of the woofers enclosure sand filled in order to make the speaker solid. what do you thing about that ?
one thing I'm yet to understand is the baffle step compensation... is there a way to measure/calculate/know the acoustic centers of the speaker drivers? (or is this just a very simple thing?)
is the baffle step compensation achievable by recessing the tweeter and mid (in a way similar to a horn loaded speaker) in order have a better correction?
I can make a blade to mill the wood into a horn-like recessed driver. I just need to have it calc. before
that makes my wondering about using coaxial speakers like the ones I've seen/listen in KEF speakers (and found similar selling at Europe audio) link:H1333-08/06 - Seas T18RE/XFCTV2 7 inch coaxial - Europe Audio
the cost of a (decent) coaxial driver will be more than a "good" mid and a tweeter... but if it helps to solve a problem I'll wonder about it!
Sorry for the long thread...
OK, Baffle step correction is different to physical alignment.Difraction Loss / Baffle Step Compensation (BSC) Circuit Calculator
Also, whether a passive radiator is a better bet than a simple closed box, depends on which bass driver you had in mind. Generally a QTS greater than .4 = closed box, Low QTS drivers (0.2-0.3) will benefit from a passive radiator.
Mick.
Nice way to go. I'm starting to figure out some of the issues here. I already read the baffle step correction from ESP but I'll read-it again and cross-it with other articles that you just pointed out to me.
I'm yet to choose the drivers since I don't fully understand the "other" issues here. I've done "a bunch" of speakers with very cheap drivers so I know the problems physically I now want to correct them and build a "good" 3 way system with the correct values & drivers and therefor: sound 😀
the driver I had tested had a "high" QTS so I got a misleading result... I'm going deeper in the drivers parameters to fully understand them... "the problem" is that I found "nice" priced passive radiators at Europe audio (easy for me to buy from there...) and now I'm evaluating the addiction of them.
plus all this, I'm considering making the main speakers sealed. I would only make reflex bass for surround/near-field monitors with active equalization to correct for the box size "not being perfect"
thanks Mick!
Hi again!
I already have "all" FRD Consortium tools (including unibox) but thanks 😀 any input its worth!
I messed up! got confused between baffle step and phase/time alignment...
link:Phase, Time and Distortion in Loudspeakers
so... : is this compensation achievable by recessing the tweeter and mid (in a way similar to a horn loaded speaker) in order have a better correction?
I can make a blade to mill the wood into a horn-like recessed driver. I just need to have it calc. before.
so... any input appreciated 😀
The target is to have the sound coming from the drivers in perfect timing to your ears . this can be reached in many ways 1) by using a single driver ,preferably with limited BW 😛 2) by using 2 or more drivers with the necessary dividing network (crossover) ... 3)by splitting the signal at line level ,preferably in the digital domain so the time costant (delay) may be managed much better than in the analogue world .
Each modality has its pros and cons . Perfect phase alignement then must be measured with sophisticated instrumentation ,after the whole work is done ,because the ear cannot discern phase ---under milliseconds---
hi, the goal is active 3 way (tri-amp) with analogue crossovers (not "smart" digital one...)
thanks for you post 😀
and all comes to:
from this forum I already got 2 answers I needed. passive radiator will 'only' be useful with drivers with low QMS (didn't know this...) plus I was messing up with 2 different concepts: baffle step (easy to calc and fix) and time/phase alignment...
one of the "old" techniques to fix the time alignment was to recess the tweeter and mid in the baffle (in steps) but this causes to much diffraction and its worse than a slight out of phase driver.
so I'm wondering, making something like a waveguide/horn to the tweeter and mid will help to get the drivers phase (near) good ?
I've read this article Practical DIY Waveguides - Part 1 but it is not fully clear to me yet...
I rather waste much time in software's and on the box itself than in cutting it down for burning wood because it is not right...
other detail its the fact that I want the amp to be in the speaker itself. so it will have a separate compartment for this purpose.
what about the sand filed compartments ? (on the sides. maybe the back either) this technique has been used before... but "in real life" will it help much? its not that hard to make so I'm looking at it as an extra.
One thing you might think on, if going active with the all the amplifying electronics in the speakers or close to them, is using true balanced interconnects.
And by "true" I mean using real balance/unbalance chips.
good thinking! I was going for balanced... but that is the least of my problems 😛 its actually the 'module' that would be very cheap to improve/change so... that's a pretty good Idea!
edit:
actually... I was looking at Project 125 from ESP (http://www.sound.westhost.com/project125.htm) since its quicker to use and has, for sure, less problems to solve. this unit would enable me to have an subwoofer output (4th way) in the speakers so, If i need I can throw a party with this speakers and a sub. (its possible that I will include a compression/protection circuit... bypass-able just in case.)
What are you going to use together with the WG ?
A silk soft dome tweeter ? A ring radiator tweeter ? An alu or titanium dome tweeter ? A compression driver ?
It's better to use tough materials . A soft dome it's going to suffer from the extra stress given by the surrounding surface .
By augmenting sensitivity over a broad range (1-2 octaves 😛 ) ,the WG may be also useful in making a simpler crossover ,i.e. only one cap .
Screenscope
the objective its full active 3 way the only thing I'll put between my tweeter and amp will be a protecting circuit and a capacitor... hopefully very 'neutral' to sound...
as for the material of the tweeter itself, I don't know yet. since it is active... I will manage to control the SPL output of all the drivers with less effort than with an passive crossover. even the baffle step compensation is achievable with a simple low power RC network at the power amp inputs.
just like this, equalizing a "odd" peak or dip in the audio spectrum of a device will be very easy indeed.
I'm yet to buy a screenscope (link:http://www.screenscopetraces.com/) since I have little information on anyone near me using it. the price of that unit will make any FTT capable oscilloscope run with fear! its like 2000 to 400!
does anyone know this unit deep ? it has a pretty informative website!
Low power 😱😕
At line level ,'devices' should pump no current
On the other hand , I hadn't read much things on BSC as on this forum .
For me , BSC is part of the process in making a loudspeaker system : you choose the woofer ,you measure it ,or rely on the measured data from the fabric (which may have been done on an infinite baffle ,or IEC type or something else ,better if specified ...),choose an acoustic load for it ,calculate the crossover ,measure it . BSC is a derivation of woofer response + environment ....
Going active , it means that you choose a sufficiently low freq cut for the woofer so you can boost it ...even without EQ 🙄
At this point , I would choose a 4 way system :warped:
Low power 😱😕
Actually the 4th way will be a subwoofer (or two). I've got one but it will be changed... not just now but someday... (depends on the costs VS output 😛 )
Of course the 4th lowest way will be a <100Hz (self-powered) woofer ,which is properly called a subwoofer .
The pros of 'active' is that you may choose a woofer that doesn't need to go on fire to reproduce the first octaves ,which are delivered to the sub .
So first you have to fix what are your needs in terms of power , size ,listening hall characteristics etc.
I'm going to make some simulations & calculations to find some drivers and come to have "problems" such as time alignment, baffle step, diffraction, and on. the power is the least of my problems since I don't have the drivers choosen yet. so If I come across some sensible drivers I'll need less power for the same SPL output.
I'm also evaluating for the use of a passive radiator or not... but this part is coming to an end. probably wont use one at all.
there are a few issues that I'm trying to solve just before stepping out to the wrong place 😀
