I'm looking to build a small (low power) sub. The smallest sub I found in my region is this one Pyle - PLPW6D - 6'' 600 Watt Dual Voice Coil 4 Ohm Subwoofer
As you see there are no real specs available to build an enclosure for it. Is there a general rule for subs ? What would be the best, a standard closed box or something more advanced ( I think you def need specs for that ).
