Hey guys, i'm looking into setting up a good mid-range enclosure for these speakers . I will be using them for both vehicle and home play. I already considered how they will be powered and run at 8ohm, etc
I'm looking for a box design that will capture a good frequency response, as low as about 500hz or so; from midrange to midbass basically. So I don't know if i should make one box to fit all 4 or make 4 separate boxes for each or 2 boxes that hold 2 speakers each.
Let me know what you guys think.
If it helps, i will be using these horn tweeters with them.
In a car, you'd probably want to mount them in the kick panels with custom enclosures, or in the doors. Box volume shouldn't be critical; the main thing is to use plenty of stuffing, and maybe non-parallel walls to reduce the "honk" of internal resonances.
Custom kick-panel pods can be made using MDF, fleece, and fiberglass. If you google those terms you should find some info.
