EMT TSD-G
Hi there,
I am about to try and mount a DL 102 into a EMT TSD G headshell and I notice that the cartridge mounting pads on the headshell are of a different height. This does not seem to be a fault but as per design. Anybody any idea why this is? Not a big problem to reso😕lve by use of a washer or two I am sure. Just curious??
thanks..
In fact, the EMT TSD-G headshell allows stylus azimuth adjustment.
To mount a non-EMT cartrige in the TSD-G shell, you need a kit consisting of the following accessories:
- 1 spring washer
- 1 plexi strip
- 2 washers 2,6 mm
- 1 mounting screw M 2,6 x 5,5 mm
- 1 mounting screw M 2,6 x 5 mm
See attachment for drawing and (German) text.
Jos
