Eminence Lab 12 subwoofers
I've got three lab 12 subs for sale.
Two are re-coned (per the original owner??!!). All I know is they have non-original dust covers for sure. Seem to work okay. They look a little on the rough side.
$50 each.
One sub is all original and works great. Looks good too. I'd like $75 for this one.
Had planned to use these for building LabHorns but never got around to it.
Plus shipping from Texas, USA. I use FedEx and will toss them in cardboard boxes with lots of bubble wrap unless someone has a better idea or pays for UPS to package them.
$164/each at Parts Express.
Eminence LAB 12 Generation II 12" Subwoofer
Eminence's LAB 12 subwoofer driver is recommended for vented, sealed, and horn-loaded professional audio enclosures. The driver features long-throw construction with a heavy-duty 12-spoke die-cast aluminum frame and Kevlar® reinforced paper cone. In a horn-loaded configuration, a pair of these 12" drivers can produce low-distortion bass output comparable to 6 or 8 conventional 18" woofers. Also great as an automotive sub.
Specifications: • Power handling: 400 watts RMS/800 watts max • VCdia: 2.5" • Le: 1.48 mH • Impedance: 6 ohms • Re: 4.29 ohms • Frequency range: 25-125 Hz • Magnet weight: 160 oz. • Fs: 22 Hz • Sensitivity: 89.2 dB 1W/1m • Vas: 4.4 cu. ft. • Qms: 13.32 • Qes: 0.39 • Qts: 0.38 • Xmax: 13 mm • Dimensions: Overall Diameter: 12.32", Cutout Diameter: 10.98", Mounting Depth: 6.44".
