hi all, i ve got a problem posting files in the site..
i m using simetrix to design circuits, and it convert the
sx schematic file to an EMF image, DIY audio uploader tell
me that this is an unvalid file, and it doesn t appear on the
uploader tool, thus it s not supported..
i did convert the file to gif or bitmap using a soft, but then
the the components appear in a dark page, and there s
no more values and reference of the parts...
does anyone have a solution?. thank you by advance..
Hello,
If you would like to post a file such as EMF (or any non "web graphic" file), just zip it up and post it as a .zip file. I'm not familiar with the software so I can't help you to export it to an appropriate GIF/JPG/PNG format, but someone else here might be able to.
Jason
thank you, make sense....will try this way..
Hi, screen capture + Office picture manager edit + IrfanView convert to JPG, will work as well...
thank you mosquito, i ll try, although zipping the
file did work...
the zipped emf file is here :
http://www.diyaudio.com/forums/solid-state/155993-awb50-simple-power-amp.html
regards,
wahab
Hi, by now I'm going by the tubeway, but I really like your design. I'll try it when, and if, my skills grew .
hi, mosquito, just warn me if you try the thing, so i can help...
regards,
wahab
- Site
- Forum Problems & Feedback
- EMF file format
