Hello
A little while back i got a schematic from Quasi for a op-amp based power amplifier with a CF mosfet output stage .....well i have made a proto type of the circuit and it works.....i would like to get the article on the circuit it came from a Elektor article......in the 70's or 80's.If anyone have it .......could you post it or email it.....also if anyone have a pcb layout for the Crescendo power amplifier......the one with two pairs of mosfets .......could you post it...too
now, back to the current -dumper op-amp/mosfet power amplifier as i said it works.....so far i just want to know more about it (circuit) how it works,ihow to tweak it....etc
THANKS
Dusk
THANKS
Dusk
You have mail..pls check...'ve sent a circuit mosfet amp using BUZ23 ....I have the circuit u mentioned but am still to find will try to send ASAP..until then
