Elekit Wood Cone Speaker
For you DIY enthusiasts, Elekit Japan released as set of new DIY speakers, the SP-WC01. In this little kit you have two enclosures (15mm thickness), two 10cm wood cone speakers, two gold-plated terminals, acoustic material, and internal wiring.
If you're a good handyman you should get speakers which provide a frequency response of 118Hz-18,000Hz, sound pressure sensitivity of 90dB, an impedance of 8Ω, and a power input of 30W
Type 10cm multilayer wood cone full-range
Impedance 8Ω
Maximum input 30W(music)
Frequency response 118Hz ~ 18kHz
Output sound pressure 90dB/W・m
Lowest resonance frequency 118Hz
Effective vibration diameter 42mm
Magnet weight 380g
Total weight 970g
Enclosure Specification
Material
MDF (15mm thick)
Urethane coating
Size W180xH272xD210mm
Weight
Approx 3.2kg/pc
YouTube - Elekit Wood Cone Speaer - Building Demo
SP-WC01BR (Brown) $350.00
SP-WC01BL (Black) $350.00
SP-BR02WM $ 600.00
SP-BR03WS $ 600.00
ELEKIT speaker
VKMusic.ca Home page
