Elekit - TU-884CD 12AU7 Vacuum Tube CD Player
>Click here - the INSTALLATION VIDEO CHIP
YouTube -TU-884CD
Elekit Japan TU-884 Vacuum Tube CD Player
There is a limited edition TU-884CD, a vacuum tube CD player.
This DIY vacuum amp kit is part of a larger retro trend in Japan, taking modern products and giving them a classic feel. Everyone has a home stereo in some form or fashion, but vacuum tubes give a feeling (and a glow) that shows style as well as musical appreciation.
Give your IPOD a second life by connecting it to this CD player. Mesmerize in the quality of your tunes.
- Vacuum tube: 12AU7 X 1
- Frequency response: 20Hz - 20,000Hz
- Sampling frequency: 44.1kHz
- Signal-noise ratio when 0dB:81dB(ASP OFF),80dB(ASP ON)
- Harmonic distortion(when -20dB):0.1%(ASP OFF),0.32%(ASP ON)
- Pickup: semiconductor laser (1-bit DAC)
- Output: 150mVrms (0dB when 1.5V)
- Function: Anti-skip
- Play mode: REPEAT(1/ALL), INTRO, SHUFFLE
- Power supply voltage: AC100V-120V 50/60Hz
- Power consumption: 6W
- Weight: Approximately 3.3kg
If you are interested in ordering one of this, contact us now to reserved your DIY tube CD player kits before they run out. Supply is limited.
Price : 375.00 (DIYAudio Member only)
VKmusic
