Elekit 8600S tube rolling question
The heater voltages are different, so no it won't work at all.
6FQ7 = 6V heater (pins 4-5)
12AU& = 12V heater (pins 4-5)
The 12AU7 can be configured to work on 6V, but the heater pinout would be different.
Short pins 4-5 for one terminal of the filament supply. Connect the other supply lead
to pin 9, which is the filament center tap. Now the two halves are in parallel, for 6V.
