So I decided to try my hand at building an ESL. You give me some subwoofers and I can do just about anything with them, however these were a bit of a challenge.
I basically followed this guide, changing a few things as I saw fit. Jazzman's DIY Electrostatic Loudspeaker Page
Well, here is a video of the current product. Disappointing to say the least.
http://s59.photobucket.com/albums/g320/bball09124/?action=view¤t=20120310_015331.mp4
Now, on to trouble shooting. You have to turn the volume up nearly all the way to get a tiny amount of sound. And the sound you get sounds muffled and distorted. What might be giving me trouble, or what tests can I run to narrow down the problem? It could be my poor soldering skills, diaphragm not tensioned enough, or something else completely.
Note: I read that ESL's can be dangerous, and they give you quite a shock if you touch them. Right after I hooked up the speaker, while my back was turned, my Dad walks up and starts touching the speaker. No shock. Perhaps that is my problem.
I would first trace all of the connections and verify them to the schematic. It could be something as simple as as reversed connection to one of the step up transformers or the little transformer in the power supply, or a reversed diode in the power supply. I was helping a buddy of mine build some speakers once and he had reversed a connection to the power supply transformer; which immediately shorted out the affected winding as soon as we powered up the circuit -- had to replace that transformer).
If the wiring looks OK, I would then check to verify that the power supply is putting out. You can't check the power supply output voltage with a standard DVM unless you have an HV probe with it (that much voltage would burn out most DVM's). What you can do--- and please be DAMN CAREFUL not to electrocute yourself-- is, with power off, tap into or disconnect the lead from the power supply to the center-tap of the step-up transformers, and also tap into or disconnect the lead from the power supply to the diaphragm. Then, power up the power supply, and just brush those two lead ends together-- you should get a nice spark if the power supply is working. The output resistor may not pass enough current to give a visible spark so you may need to bypass it with a jumper to do this test. Again--- be very careful not to touch any uninsulated portion of the wires--especially if you bypass the output resistor, as you could then get potentially lethal current out.
BTW, you can safely touch one stator while the panel is playing but it's very risky to touch both stators while the panel is playing!
Have a look and keep up posted!
Charlie
Charlie
Reading stuff like this makes me nervous.
I'm just getting ready to start working on a pair of panels myself.
I hope you find the problem and that it's easy to fix.
Can you post a close up of your transformer interface block it would be easier to see if they are wired correctly.
From the sound of the video it seems as one of them is out of phaze with the other.
the distortions that you are hearing is what is left over frome the transformers saturating and/or the amplifier clipping from it being so high.
I get absolutely nothing when I hook mine out of phaze.
Do make sure that your bias supply is working as Charlie Mentioned if it is not working than you will get little sound out of the panel as well just like the video.
Make sure that all of the diodes are going in the proper sequence of direction as this can get confusing at times I have done this myself a few times.
You can check the supply with an arc test,Just make sure that you are insulated from any of the feed wires and that you are using the ground wire to probe with.
I usually use a screwdriver connected to the ground to do this.
always use a series current limiting resistor of at least 1 megohm as well from the output of the voltage divider.
If you don't then pulling an arc could cause an an over current draw causing a diode or few to short if they are of the low amperage types and they would have to be replaced.
This I have done as well.
You can also make your own voltage divider to measure the voltage out of your supply as well by using a bunch of 10megohm resistors in series.
As I have shown here,
http://www.diyaudio.com/forums/plan...tor-insulation-mylar-coating.html#post2767712
http://www.diyaudio.com/forums/plan...tor-insulation-mylar-coating.html#post2772703
http://www.diyaudio.com/forums/plan...tor-insulation-mylar-coating.html#post2773108
http://www.diyaudio.com/forums/plan...tor-insulation-mylar-coating.html#post2780153
Here is the schematic of my supply just to show the resistor divider block that I had made,
http://www.diyaudio.com/forums/plan...tor-insulation-mylar-coating.html#post2848194
Cheers !!
jer 🙂
P.S My very first panels didn't work hardly at all and it was all due to a failed Bias supply or not enough Bias voltage. 🙂
Cheers !!
jer 🙂
Thank you very much for the input. I basically threw them together because I was under a time constraint, so I am sure if I spend some time I can find and correct the problem. It will be some time before I have a chance to work on the speaker, but I will surely update this thread when I get to them.
if the polarization doesn´t charge the membrane You may be tempted to push up the volume, thereby creating distortions, because even a non-polarized membrane will give a tiny bit of output. Check the membrane when switching on the polarizing supply. It should be pulled towards one of the stators. The deflection may be easily viewed as a reflection of a light torch.
Also, at the first couple of switch-ons most panels will release some low level tickling noises, the so called ´birth-cry´. If the membrane doesn´t deflect or the panel keeps totally quiet, the chance is high that the membrane isn´t charged up at all.
I always test the charge-up without the second stator, ie. the open panel to be able to recoat the diaphragm or the contact point if necessary.
jauu
Calvin
jauu
Calvin
soaps are not usable as coatings. Change to a decent coating. Sources and materials You´ll find in other threads here.
jauu
Calvin
jauu
Calvin
I have never tried dish soap I know other have used it with limited success.
You would be better off using a staticide type product like Licron and Licron Crystal or some prefer staticide 6300.
Shelf life seems to be an issue with the latter.
If you want to try a DYI type of coating, many report good results using a coating made from PVA (white) glue.
I have experimented with mixtures using this method and found that I needed to use a little (a few drops, 3 or4 or so per 2 onces) dish soap (Dawn) to cause the mixture (1:5 to 1:10 ,glue/water) to wet the mylar properly with out beading up.
Once it is dried it leaves a very very thin and almost transparent coating on the diagphram.
Although I personally have not used this method yet but others have and report that it works well.
I have messed with it though and have documented my experiments in one of these threads with many closeup photos of the coating results .
I still have two nearly full cans of both of the techspray products and is why I haven't tried it yet.
I rarely have to replace any diagphrams (only due to burn holes in them).
The last one I had just burned up was one of the original diagphrams that I had made in 2003 with the orginal formula licron spary and it had worked flawlessly every time I powered up the panel.
jer 🙂
jer 🙂
Soap works well as coating if you like a simple coating just to test your panels, but as it's biodegradable it's not durable. 😉
(Fabric softner works just as well! )
Check out the sticky in the section and you'll find different DIY coatings that are tested and work well!
Good luck with your build, and keep us posted!
/R
/R
That's the main reason of your panel not charging up properly. Being a beginner trying a new thing is nice, but it will take a lot of trials and errors. If you can, please try some of what we've suggested.
Wachara C.
Wachara C.
I take Dishsoap...no water... no nothing.. put it right on the mylar with a cotten ball thin cote...works ever time..an well last monts...high output...i wash my panels ever 6 monts...if i need more ezey..other are right about some better ...but you have this on hand .. works great...all esl panels cane be made to re-open..make your life ezey...i say you may have a leak..in the front or back metal panel...goodluck
Looks like I will try a different coating, as well as testing the transformer. I made them with foam tape, so they can be taken apart. I have plenty of leftover mylar so that is no problem.
tyu, what do you mean when you say
"i say you may have a leak..in the front or back metal panel...goodluck"?
The dish soap should have worked. I use and recommend Licron Crystal ESD coating because it's durable and sticks like a bandit to Mylar. However, I've also tried dish washing liquid applied undiluted with a cotton ball (can't remember the brand but it contained the conductive ingredient, sodium laurel sulfate). Sound-wise, I couldn't tell the difference between the soap and the Licron Crystal--- both sounded great.
Do you remember what brand/type of dish washing liquid you used? Mine did not include sodium laurel sulfate. I shied away from that Licron stuff because of the price tag, $40 for some spray is tough on a college budget.The dish soap should have worked. I use and recommend Licron Crystal ESD coating because it's durable and sticks like a bandit to Mylar. However, I've also tried dish washing liquid applied undiluted with a cotton ball (can't remember the brand but it contained the conductive ingredient, sodium laurel sulfate). Sound-wise, I couldn't tell the difference between the soap and the Licron Crystal--- both sounded great.
I see many different formulas for the coating, but I am having trouble picking one. I see chinsetta posted this recipe
"1. PVA glue.
2. Water.
3. Graphite powder.
You add the mixture of 1 unit of PVA glue with 2 units of water and 1/10 unit of graphite powder. Take your time to stir the mixture well. It will become dark grey in color. Using a soft sponge, apply the material on the diaphragm. Only very light coating is needed. Once it's dry, it's good to go."
This seems relatively simple and cheap. Would anyone recommend a different formula?
Here is the link to some of the PVA dicussions,
http://www.diyaudio.com/forums/planars-exotics/109789-esl-diaphragm-coating-7.html#post2078272
jer 🙂
jer 🙂
I just walked into the kitchen and checked the label ingredients on a bottle of Dawn dishwashing liquid, and it does in fact contain sodium laurel sulfate; which means that Dawn would work fine (although I can't personally vouch for its longevity).
Bear in mind that you need the coating to contact the copper foil charge ring (or whatever contact to the power supply lead you are using)-- but you don't want the diaphragm to conduct charge all the way to its edges, as this might allow charge to leak off the diaphragm along its edges. Before coating the diaphragm, mask off the outer 1/4" or so of the periphery edges.
One more thing, if you are using foam tape type spacers: The problem with soap is that the foam tape spacers won't stick to the soap coating on the diaphragm. You can always over-wrap the panel edges with tape to hold the panel together along the edges but, before coating the diaphragm, you will also need to mask the areas that contact the vertical support spacers, because you will need the center-support spacers to stick to the diaphragm.
Good luck with your project!
Thanks for all your help!
I will report back when I have tweaked my design and hopefully I will have a sweet sounding setup!
From your film it looks as you are using two strips of tape in your vertical spacers - why? (aid stability?)
/R
/R
- Planars & Exotics
- Electrostatic Speaker Help/Trouble
