I recently bought an ampliwire last month. I really don't know what model it is because I only see Ampliwire written on the front.
I looked at the bias and Dc output ajustments. For each channel, I have 90mv across each (4) big 3W (.22 ohms)resistors that goes to output transistors. v+ and V- for the output stage are +31 V and -31V
Is 90mv inormal across the .22 resistors ?
Can you identify this model ?
I'm also tempted to bypass the input capacitors. Good idea ?
Thanks a lot
Thanks a lot
Bias adjustment
Hi
The bias should be 10-15mv on the 0.22 resistors which be
45 mA to 65 mA per device. The 90 reading is too high.
Tks
Hi
Tks
it seems that nobody adjusted the bias in this amp so I presume that it is working like it is since a long time.
If I keep it at 90mv across the .22 ohms resistors, it should work more in class A so the sound should be better . Right ?
What model do you think it is ?
