Dear diyaudio forum,
I have a hornresp design showing the following curve for Electrical Impedance (see attachement).
What ohm value should I choose for the amplifier?
What kind of issues could emerge with those two peaks (going over 150 ohms)?
Kind regards,
Simon
Kind regards,
Simon
If the horn loudspeaker is designed to be driven with voltage, like almost all modern loudspeakers are, then any amplifier with near zero output impedance designed for nominally 8 ohm loads (*) should work well and the impedance peaks will cause no problems unless you use excessively long and thin loudspeaker cables.
(*): That is, just about any amplifier except valve amplifiers without feedback and some exotic types.
Thank you for your response!
So should the amplifier be over or under 8 ohms? Hopefully that question makes sense.
Kind regards,
Simon
Kind regards,
Simon
Although there are high impedance peaks, the amplifier only needs to be rated into 8 ohms as per the previous post - it doesn't have to be rated above 8 ohm.
For most of the frequency range the impedance is in the order of 8 ohm and that's all you need to worry about.
