Electret mic preamp - will phono preamp work?
I have a stereo electret mic that is used on things like DAT and MiniDisc recorders that have "plug in power" (2-12vdc bias). Does anyone know if a phono preamp would allow me to use this with an input that needs line level? Could I plug it into a receiver with a phono input? Or if there is an inexpensive preamp out there instead?
certainly, phono cartridge (mm) and mic provide roughly the same output, few milivolts, need roughly the same amplification to become line level signal,
some old phono preamps actualy came with swith for flat fr response to be used as mic preamps
but before you embark on modying your phono preamp, you should consider building dedicated mic preamp
there is ton of good schematics out there
you might suceed modifying phono preamp, but you might not, might become unstable, oscilate....at the end you just might destroy perfectly working phono preamp
adason said:
built your own mic preamp, its easy, its fun, and thats what diy is all about
Alright. I'd been hoping it wouldn't come down to this (I'm no stranger to a soldering iron, but I am to audio circuitry...) 😉 Looks like I'll probably be making my own.
One last question before I decide: If I use software equalization to flatten a mic input through a 70dB S/N ratio phono pre-amp, how much audio degradation will I have when compared to a simple DIY pre-amp?
Thanks for all your help!!!
I assume your original question was because you had a ready made RIAA preamp that you wished to modify rather than starting from scratch. It should be quite easy to make the frequency response flat and change the gain by removing capacitors and changing resistors in the feedback path. However, no one seems to have mentioned that you will still have to come up with some phantom powering arrangement. You do need to do this. Check out http://www.epanorama.net/circuits/microphone_powering.html or Google "electret"
