El34 PP advice needed
Hi to All
As my new amplifier is at the stage of quotes and pricing , I decided to give it another go and "mix" a little with the old one.
Amp is based on Jolida schematic as below:
View attachment 302b.pdf
PSU has been slightly improved :CLC filter ,bridge diodes paralled with caps, higher values of electrolytics , electrolytics paralled with PP caps , I used stepped lader attenuator and also added switchable PSE configuration.
I wonder if there is room for an improvement in pre- stage , phase splitter ( use different tubes , circuit , etc.) or output stage .
Any advice would be very welcome
Cheers
The topology used by Jolida is a variation on the "classic" Mullard 5-20 theme. That's very well proven. The selection of a 12AT7 as the LTP phase splitter is excellent. I have reservations about a "totem pole" 12AX7 serving as the voltage amplifier. I'd like to see something with higher gm there. Also, put a 10M45S constant current sink (CCS) in the LTP's tail, instead of a resistor. Forced symmetry is SWEET.
BTW, watch out for excessive gain. "Gobs" of gain are not needed, when the 2 VRMS of a CD player are the driving signal.
Fairly standard circuit arrangement.
EDIT: Ah!! I see Eli reponded while I was still typing - seems we both agree about a current source for the driver.
If I were building it I would make the 12AT7 driver anode loads R7 and R8 the same value = 22K and replace the R6 resistor with a current source. A simple "Ring of 2" current source would be fine. Set current source for approx. 3mA.
C1, C3, C4 need to be good quality caps, I suggest Wima Polypropylene Film/Foil.
Ian
There is an interesting cascade of knock-on effects in that amp. Adopting fixed bias means lower value grid leaks for the output. This means a lower impedance phase splitter is needed, hence 12AT7 instead of 12AX7. This reduces gain a little, so choosing a triode input (presumably for reduced noise) means a totem pole/SRPP can restore some of the lost gain. You can just about get away without a CCS tail for a 12AX7 PS, but 12AT7 needs one because of the lower mu.
One thing to watch when making changes to the 5-20 circuit, or derivations of it: the original had only marginal LF stability, with a subsonic peak. Changes can push you further down this road. The forward path through the amp has three LF roll-offs: R4/C1, R9/C3 (+ R21/C4), and the OPT. The original circuit had an LF shelf in the output stage cathodes, which might have helped or hindered a little, but fixed bias gets rid of this.
Hi
Thanks for reply , excuse me ignorant question but I am not very familiar with CCS. As I understand one of the advanteges would be close to perfecr DC balance , what else . What does wait for me on the dark side?
A CCS tail gives perfect AC balance, so you should get cancellation of even-order distortion. It does not affect DC balance, which is set by the grid voltages and the triode matching. You may get a little DC imbalance due to the grid current for the second PS triode causing a voltage drop across R10 (in the original 5-20 circuit).
How to built(calculate) CCS , where should I start ?
If you want to use the IXYS 10M45S, it's pretty straightforward, you need to pick the value of the resistor to set the current, and use another resistor for a gate stopper to prevent oscillations.
You can also do a ring of two CCS in the tail, although I have no idea how to size the resistors, etc. There is a great summary of various ring of two CCSs in Morgan Jones' Valve Amplifiers-3rd edition.
Here are two very similar projects based on the Mullard 5-20 with CCS in the tail of the LTP.
http://www.diyaudio.com/forums/tubes-valves/156699-mullard-5-20-kt88-pp-blocks.html
http://www.diyaudio.com/forums/tubes-valves/161702-opus-5-0-modern-mullard.html
Hi
I am going to place an order from KandKaudio , they also do some CCS kits ,are they any good ?
Which one to choose :
- Compact Current Source Kit - up to 3 watts
or
- Large Cascode Current Source Kit -up to 7 watts
One more q. , are they directly connected between cathode and earth or I need extra Power Sup. ?
Happy Easter everyone!!!!!!!!!!!
I am considering new OPT for my PP amplifier , and I am torn apart between Lundahl and Tribute .
Anyone has compared them?
How they differ?
Is there anything else worth considring in similiar price tag?
Cheers
