For a summer project, I would very much like to try to make a SIMPLE guitar effect pedal. Possibly something like a Fuzz, or some sort of boost or microamp.
Can anyone suggest how to go about this, where i could find a tutorial and other useful informtion, i would very much appreciate it.
Thankyou
Peter
(By the way, I'm new to this forum, so Hello everyone)
Thankyou
Peter
Here are lots and lots of them: http://www.generalguitargadgets.com/v2/
I made about 4-5 effects, but not from that site and none of them worked 🙁. Then again, when I made them I knew nothing about electronics at all and I probably made some stupid mistakes. I might try again one day 🙂.
Google for 'proco rat schematic' .. simple circuit.. be very usefull as a good guitar FX pedal, highly reccomended....
that generalguitargadgets site cant be beat.. you can even order PCBs for most of the projects.. follow the part placement diagrams and viola.. I made some of those and they work great(try the Red FuzZ..quite easy, and sounds sweet) I asked to order a PCB he didnt list and he made one for me.. nice guy.
I will also chip in here for that general guitar gadgets site.
this is how i got my start in electronics. electronics was something i wanted to get into, and i thought, well, i play guitar, and pedals run off 9V batterys... what a safe way to get a start!!! i made some octave/fuzz pedal... and it worked!!!! i was happy, and have been making electronics projects ever since, although these days i've moved into the world of vacuum tubes, where the voltages can bite if you're not careful.... but that's what i love about pedals, you can be care free as they don't bite!!! (unless you dropped the metal case on your little toe while on concrete ground as i did... needless to say i found it hard to walk around for a little while after... my little toe just about became my big toe... and it really hurt!)
hope you do well. the stuff on general guitar gadgets is pretty much foolproof, and spells everything out pretty clearly, especially if you use a PCB... i did mine point to point, so it was a little more tedious.
you might want to find a couple of articles on the internet about identifying components and values though if you're new to this... also, find data sheets for any transistors you use which will give which leads are your colector/emiter/base... this is important... wire in the wrong way, and it won't work...
later
later
later
later
i've done some guitar pedals
4ms phaseur fleur and tremulus lune
the pcbs
4ms phaseur fleur
4ms duo distortion
the pcbs
4ms phaseur fleur
4ms duo distortion
Several of the GenGuitGadgets items are for my original designs that can be found at http://www.muzique.com/ so you might want to look at the full articles I have posted. There are some other free projects available at my site as well. Enjoy!that generalguitargadgets site cant be beat..
regards, Jack
Does anyone try to copy the PCBs of the GenGuitGadgets?
I'd like to make them to a local PCB industry.
There is also a whole section devoted to effects over at www.ampage.org Sorry, I don't know how to make that a link. Ampage is a site devoted to do it yourself amp and effect builders.
Oh, it made itself a link. I am old school.
- Live Sound
- Instruments and Amps
- Effects Pedals
