Effect of curve family on amp design?
How does this affect amplifier designs/performance and part selections?
In theory, this Early effect should not affect the linearity of an amplifier (it is linear, as a first approximation), just the ultimate amplification possible (like in µ-amplifiers). But in practice, it has some non-linear components, which means getting rid of it (with cascoding or similar schemes) generally improves the linearity too
PS
Now, lovers of the triode-sound may disagree with the above, but tube-lovers live in their own universe, with their specific rules.....
If you look at a family of curves for a BJT, some will exhibit more-or-less constant current for a given base current as Vce changes. Nice horizontal lines. Others will show the current increasing, sometimes wildly, as the Vce increases.
The ones exhibiting horizontal lines have higher collector output impedance and behave like a "more perfect" current source.
The good old 2N3055H (hometaxial-base) used to exhibit those nice horizontal lines... 😉
