EF86 Triode Mode
Hi All,
When running an EF86 in triode mode, is there any advantage to be gained by inserting, say, a 100e resistor between the Cathode & G3, or should one just strap the two pins together? Would a resistor affect the gain or any other characteristic of the valve?
The EF86 is the first stage of a Mullard 5-20. The HT & Cathode resistors have been changed accordingly to give about 1v DC on Cathode & correct Plate voltage.
-Eric
Family_Dog said:
Hi All,
Hi there.....inserting a resistor on the g3 brings no performance advantge and will pick up noise.....so connect g3-->cath. It isn't in tube data sheet.
Make sure that pins 2 or 7 (or both) are connected to chassis.
see www.frank.pocnet.net/index.html
richj
Hi Rich,
Thanks for your reply. I have built four amplifiers with the Cathode & g3 shorted out, and one with a resistor betwee the two terminals. Although I couldn't hear any difference between the amplifiers, I was wondering which would be the correct way to go, and the reasons behind the fact.
I will remove the resistor from the one amplifier and short the pins out. With the input shorted and 'scope set at 10mV/div, I could detect absolutely no noise on any of the amplifiers on any of the amplifier's speaker outs.
The link you gave seems not to exist?
-Eric
