Hi there,
This subject is sort of an extension of an ealier thread about EEC legislation and class A amps.
Been a very Eco minded sort of a bod, it troubles me every time I switch on my Class A push pull valve amplifier. I am thinking eventually I may well go off the grid, and then a Class A amp becomes out of the question. So my question, is there anything out there that can come close to the shear quality of sound availble from a top notch class A valve amp ?
Last night I plugged in my best implementation of a LM3875 gainclone and had a listen. It sounded lovely and certainly I could live with it. However when I switched back to the Valve amp the difference was not subtle. Low level detail, stereo image and width, silky smooth midrange. It had it all in spades. I am certain that there are better versions of the Gainclone, but I am almost certain that there will still be a significant margin of difference.
So my question is - what options are open to me to build an amplifier which can compete/better my class A PP valve amp, whilst offering the efficiency that my principles will let me live with. As far as i'am concerned the gainclone rought is a dead end. I was thinking maybe something in the emerging field of class D.
Discuss.
Shoog
Discuss.
Shoog
Shoog said:Hi there,
Discuss.
Shoog
You might want to speak to Hugh Dean about a LifeForce SS amp
module. I have tried his earlier amps (the AKSA 55) and it would
suit a tube enthusiast well.
Apparently the Lifeforce is better again. Well worth looking at.
Cheers
Terry
I don't know whether I can address the quality questions, but I'm also looking at being off-grid either partially (cabin) or fully. I've started the process of moving to Class D amps, which IMHO are likely to be the only truly viable off-grid approach. Fortunately, many of the Class D implementations can sound very good, although it may take some searching to find the ones that you personally like. The high-end Tripath implementations for example are frequently described as having tube-like qualities, and may be a place to start looking.
IMHO Class-D amps running directly off batteries is the ideal way to approach an off-grid system. Having to run things off an inverter introduces losses that greatly undermine the efficiency of the approach. You may still need a sine-wave inverter for your signal source, but without the power amps this can be very small and hence much more efficient at low power draws.
In my prototype experiences battery power also sounds far better than garden-variety conventional power supplies. I'm currently running a Panasonic XR25 off a 24V battery supply, and get impressive run times out of even a pair of 7aH cells, and IMHO it sounds great.
Whether it's worth switching over if you don't go off grid is another question, though. I'm not entirely sure that the overall energy consumption of even a Class A amp is a significant factor in your overall household consumption. Obviously that depends on how much time your amps are on. Maybe get a Kill-A-Watt meter and see what your system draws in kWh over a typical day/week/month.
It goes without saying that efficient speakers are also part of the equation. Since you're already a tube guy, this may already be covered.
...Has anybody tried to build something like Bob Carver's Sunfire amp? That would be something where the outputs are biased full Class A, but the rail voltage follows the input signal keeping just a couple of volts above and below the Collectors/Drains (for common emmiter) or Emmiter's/Sources (for current dumpers). There could always be high idle current, but low dissipation.
i would say that for me there is really no alternative, i went from tubes to class-D and class-T and now i'm back with tubes again.
My suggestion: use the best of those two worlds, combine efficient class-T with a wonderful tube preamp, a tube preamp does not consume very much power, neither do class-T!
(at least give it a chance 😎
Based on threads here, the Aussie's seem to have a corner on high quality DIY AB ss amps - Hugh Dean, Anthony Holton, and Greg Ball. Hugh intentionally trades vanishing distortion specs., to get the sound he wants.
I haven't any experience with those, but I did build Symasym's from a thread here. Pretty darn good. Users claim better sound with higher bias currents, but it would be easy to make that switchable, so one setting for background, another for serious listening. The low setting would be under 10 watts at idle for a stereo amp. Significantly better sound than the chip amps I built (both with input buffers and regulated supplies), even at that setting.
Real life power consumption for some of the AB amps is not much more than it would be for class D. For instance, I looked up digital amps and came up with a company called Spectron. Their digital amps range from about 100 watts to 500 watts. Power consumption at idle is anywhere from 20-40 watts. Yes, the efficiency is better than 90% for the music signal, but unless you listen at high levels you won't save much.
Maybe a good AB sand amp for regular listening, tubes for sessions where you really concentrate on the music.
Maybe a good pair of cans with a little tube or Fet amp is part of the mix.
Sheldon
edit: BTW I'm not arguing against class D amps. Just pointing out that the energy savings may not be much in your home.
Sheldon
Or as DWK said, high eff. speakers and something like this: http://www.hornet.hr/SM/Brian.htm
With SS rectification, not much more than 20- 30 watts per channel power consumption. Maybe even a little more power output with low consumption with a spud PP amp.
Or go active. Class A on the mid and tweeter, AB or D on the woofer.
On opportunity to get creative here.
Sheldon
Sheldon
Before you jump ship take a look at how much power other things in your household are using and figure out their contribution to your overall usage relative to your amplifier - you may find that the amp does not consume a meaningful amount of energy overall.
Offset hifi power consumption against more efficient lighting, heating and cooling - this is the strategy I am taking.
First get some efficient speakers. Small folded back horns based on Lowthers or similar..
Design a tube amplifier with high efficiency in mind.
Here are some pointers:
Design the amplifier to produce no more power than required for your pk spl + say 3dB margin for safety.
If pushpull run class AB1 with fixed bias, no energy wasted as heat in cathode bias resistors, lower overall B+ needed means less wasted power.
If SE build an amplifier based on lower power dht or idht and only enough power to do the job. Again use fixed bias.
Select moderately high perveance tubes with relatively low filament currents. Consider the 6BQ5/EL84, 6L6, 45, 2A3 and other types with relatively modest drive requirements met with one or no more than two stages.
Use solid state rectifiers and choke input, peak currents in the secondary will be greatly reduced and your power factor will closer to unity.
Heat filaments with AC only and choose driver tubes with relatively low filament currents like the 6CG7.
Choose higher quality power transformers and run them well below their ratings.
You can design a tube amp to be pretty eco friendly particularly when you take into consideration how little it is used relative to something like your fridge..
My latest SE amplifier design uses about 85W in operation and was not designed to be that energy efficient. With some thought and the above guidelines I could probably have gotten it down to about 50W.
Great ideas everyone.
My current setup is using very efficient speakers and my current amp is pumping about 7watts per channel of pure class A. Takes about 120W of power overall (I think). However we tend to switch it on when I get up in the morning and switch it off again when we go to bed at about midnight, the thought of it sitting ticking over when the wife is listening to womens hour is a bit painful.
So there are a number of options.
Have a switching box to switch from Valve to Gainclone without having to fiddle with leads all the time. I suppose this would be the easiest thing initially. Still wouldn't be adequate for an off the grid situation though.
Look seriously at some type of low power class D or class T (Class T been pure digital I take it).
I like the sound of the variable rail class A design - but it sounds complex to build.
Shoog
Shoog
I don't have a Class A amp. But I still have too many reasons to hate my tube amp. It's big, heavy and gets hot. I just got a plasma screen. I didn't read the manual (duh), but did flip through the 200-300 page beast, printed in numerous languages, and noted it consumes 220 Watts. You can almost fry eggs on it. The heat hits you when you walk by it at a metre distance. My PC is always on. I have a fixed electrical bill of €15 a month here, so economically it doesn’t matter. But I'm not a jerk just because I can be.
I solve some of that by using a Sonic Impact (just got a 41Hz AMP3 kit) for CD playback. My PlayStation and SI consume 20 Watts, tops. 12 of those are consumed by the PlayStation. The tube amp I only use when I listen to vinyl. I still hate on the tube amp and seriously consider selling it.
A modest 2A3 should be nice. EL84 could be another alternative.
As for SS, the only "alternative" to tubes that I can see is a vintage SS amp that uses output transformers, like Altec theatre amps and McIntosh. I couldn't see myself go that route. Should I decide to sell my tube amp, I will go bi-amping using two AMP3s (or the coming AMP4) and use a chip-based active crossover. While the amps may mean a trade-down, the active crossover should compensate for some of it.
How about combining exercise and your love of tubes together. You could get a stationary bike that has a generator hooked up to it. The power from the bike could power a set of batteries for a battery powered stereo.
battery powered. make you own solar panels, I am, I've got about $4k in cells.
Also, hugh Piggets book on making your own windmills. Get used (but good) batteries for free from forklift rental outlets. A battery system will give you lots of power for class A, if you do it right.
windmills can be made cheap and generate power 24/7, as you would make ones for low wind conditions...unless you live in a high wind area. Between the two you can actually end up selling energy back to the power company.
This guy has good product at good prices. One can easily DIY windmills that blow away commercial units, at far lower prices and fit your needs more exactly. When they are designed for you exact wind conditions, they end up being far more effective.
http://cgi.ebay.com/4-Neodymium-Rar...223QQihZ008QQcategoryZ413QQrdZ1QQcmdZViewItem
Put up an extra solar panel or two to 'offset' the power used by the tubes,and listen guilt free! 😉
I might just mess about with one of the Tripath amps.
I was originally thinking of the TEAC AL700P but it seems to be out of production at the moment. Anyway I think it wouldn't like my 4ohm speakers. Still the case and build was nice.
So the alternative is the the Sonic Impact hotrodded to hell. Put some sealed lead acid batteries in a new case, cut out the vol pot, increase the input cap, and it might be a competitor. Wont cost a bunch to find out either.
Shoog
Shoog
There are lots of tripath kit amps out there (and right here if you search for them) that might be easier and maybe better than modding an SI
I agree with Variac.
The SI is impressive. Quite possibly the most impressive thing in audio. But from all reports, the kits out there are superior. Unlike most people here, I don't build for the sake of building. I build only as a last resort. So I'm not going AMP3 because I look forward to solder those tiny SMTs. And I definitely don't need the extra power. The Watt rating of the SI is for real. These are serious Watts.
Signature 30
Signature 30
Shoog said:I might just mess about with one of the Tripath amps.
Shoog
Shoog,
I slightly modded an SI amp a year or so ago. Basically I just pulled it from the plastic case and put it in a smaller metal case. I changed the volume pot to a better one, added a separate power switch, a DPDT toggle to allow switching between two sources and binding posts for speaker connection.
I've been using it with a 12VDC 2.5A wall-wart type supply. It sounds very good. Oddly, to me anyway, it sounds more "tube-like" than any other sand amp I've heard. Interesting how digital, far removed from thermionic valves actually sounds a bit more like valves.
I have to admit that I can't hear enough of a difference running it on batteries to make me want to abandon the wall wart. I've tried AA and a big 12V lead-acid. But I've never had "golden ears".
All-in-all probably the best bargin in hifi today. (Plus I got two at a clearance sale with those big NXT cardboard pyramid speakers for $14.99 US each. Haven't found any more at that price though.)
Hey, I've got four SI amps for use around the house, so I'm a believer!
I just think he should consider some of the other options. Some of them aren't surface mount. Perhaps someone can list the candidates, if not a search of the forums should turn them up!
Theres currently a thread about a 10W mono digital amps which someone has designed. Hes thinking about offering a kit - but its hard to imagine a kit competing with the SI amp in terms of price. They use 8 pin sil chips (i think).
That the only issue with the SI amp - it so integrated that to do the necissary mods runs a real risk of damaging the board or chips.
Shoog
Shoog
Have you compared the environmental damage done by running your tube amps against the environments damage done by manufacturing new solid state parts and pcb's. I haven't, but I wouldn't be surprised if the tube amps don't end up looking pretty good.
- Tubes / Valves
- Eco warrior thinking of jumping ship !!!
