Ebay LCD Monitor Quality?
I've been looking around Ebay for an LCD monitor to strip and have a question. I'm seeing some great deals on some working screens but they are being listed as having "dark marks" on the screen. When you look at the picture they took it almost looks like a bruise. Does anybody think this might just be the external pieces causing the problem and not the lcd screen itself? Thanks.
http://cgi.ebay.com/Dell-1503FP-15-...701471975QQcategoryZ74932QQrdZ1QQcmdZViewItem
Look at the larger picture of the monitor and you'll see the 'bruising'.
I'm scouring the net for a good cheap panel. I know to look for XGA 1024x768, less than 30ms response, contrast ratio 300:1 or better. But what I don't know is whether or not what I'm looking at has FFC cable issues. I'm not good at soldering so I can't afford to get a difficult lcd to strip.
"So What Causes a Dead Pixel?
Occasionally the individual transistors responsible for carrying
current to a pixel will either short out or remain open resulting in
what is called a dead pixel. A "lit" pixel is one that appears as one
of several randomly placed white, red, blue or green pixel elements on
a dark background, or you may have a "missing" pixel which shows up as
a black dot on a light colored background.
"Are bad pixel only a problem on new LCDs or can a pixel become bad
over time. I mean, is the transistor failure due to production or does
failure often (or less often) occur after the LCD is in use."
"Dead Pixels can occur over time."
Even if it has some dead pixels, 30 bucks ain't a bad price for a first try. If you completely screw up and blow the whole thing you're only out 30 bucks. Anybody strip one of these lcd's before? Wondering if it's DIY friendly. Dell 1503FP.
Thanks.
This is definitely the best lcd projector forum i've found!
