Hi Folks,
I've been using ExpressPCB, but I want to be able to move away from using their services. I came across RIMU PCB, very similar and low cost.
I have been trying to contact them regarding a few questions I have.
Does anyone here use this software? Does anyone know if they are still in business, they haven't replied to my emails.
Can anyone recommend another VERY SIMPLE program, I hand route all my tracks so I don't need netlist, autorouter etc. Eagle is nice but the learning curve is too steep.
I want simple click on a pin, draw a track to the next pin etc.
I had exactly the same need and highly recommend Sprint-Layout. No other software even comes close to how easy it is to use and make your own library. It is also very cheap.
Thanks for the tip
I download the demo and it seems very easy to use. Have you produced Gerber files from it and used CopperCam?
I made a gerber as a test when I first got it, as the main reason for me changing to Sprint-Layout from my ancient copy of Quickroute was I wanted to produce files that board houses could use. Not sure what CopperCam is. I have used Sprint-Layout to produce drill files and isolation milling files many times as my friend has a small milling machine.
