EAR / Yoshino 834T
Hi!
Does somebody know what kind of Mosfets are in this amp?
http://www.enjoythemusic.com/SuperiorAudio/equipment/1206/ear_yoshino_834t.htm
The circuit topology is tube-like in that the 834T uses a high voltage B+ of 170 VDC as a single supply together with a wide-bandwidth output transformer that works in the same way as in a tube amplifier. The circuit is balanced from input to output and the output stage is push-pull (with several MOSFETs operating in parallel in each half of the circuit) in tube fashion.
Greets:
Tyimo
