Dynaudio kit plans
Dear friends.
I'm in urgent need of the old Dynaudio speaker kit plans....All
models if thats possible.
I used to be the Sole agent (oem) for Dynaudio here in Adelaide South Australia,and had the plans for .....everything dynaudio.
sadly they have walked and i cannot replace them.
If anyone can help me i will be more than willing to share my expertize with you.
Myself and a good friend of mine designed world class Loudspeakers using Dynaudio and Morel drivers for Duntech Audio some 7 years ago.
My knowlage in complex first order filter design should be help to many here in the forum.
Kindest regards.
racoon.
Thankyou Andrew for the information,but in still in need of plans for the xennon/75,Myryx,Septagon,Axis5 and Axis5mkll,Jaydee,juniour,Xennon2,and the Compound series.
Thats a huge ask i know but anything you and the boys can help me with will be a big help.
Im in the Northern Subs mate Greenwith to be exact,How far South are you Andy.
Thanks again mate.
Rod.
No worries mate.
The values your looking for are as follows......High frequencey roll of..2.2 ohms 5watt/15 ohms10watt.
Normal 1.2 ohms 5watt15ohms10watt
high frequencey emphasis 1.2 ohms 10watt...omit 15 ohm resistor.
extreme high frequencey emphasis omit both resistors.
Andy these are the values recomended by Dynaudio.
hope this helps mate.
Rod.
help with Foccus resistor values
I am experimenting with some old Dynaudio drivers and different crossovers. The Foccus crossover is working pretty good, but I am only guessing at the Rs and Rp values. Does anyone have the factory recommendations? Thanks
