Hello,
Im planning on changing all the resistors in my ST70, i know what the resistance should be but does not know if I should get the 1watt value or 1/2 value or a greater value. Reason I'm doing this is I'm putting new boards and want to be everything up to spec and also because I messed it up. Don't ask me why. Any help is greatly appreciated.
I'd use the higher rating for the 1k (nfb loop), 6.8k (B+ supply), 10k (bias circuit), 22k (B+ supply), 47k (phase splitter),
270k (pentode plate), 330k (pentode screen). Match the 47k resistors, or use 1% parts.
Also replace the selenium rectifier with a 1N4005 diode. Often the original coupling capacitors become leaky and need replacement.
Might as well install new tube sockets while you're at it.
So what should be the wattage. 1 or 1/2 or higher.? I need some value because I don't watt to screw it up. Thanks.
The 1 W rating is plenty for the ones on that list. The rest can be 1/2 W.
The 15.6 ohm resistor is a special 3W part, though it's not on the pcb.
If you had some resistors burn up before, that could be due to some other part
that is bad, or a bad connection, or a bad tube.
If you have the original carbon composition still installed you can go by those as to the size; the small ones, 3/8 inch long and 1/8 inch in diameter are 1/4 watts. I can't remember if the 47Ks are 1 or 2 watts, but it would be best to use 2. 2 watt carbon composition are 11/16 inch long and 5/16 in diameter.
Your small resistors would be best replaced by Yishay/Dale RN60D series. They are only rated for 1/4 watts, but they are 1/2 watt resistors derated for the military.
Also Yishay CMF60 series, they are the same size as the RN60D but rated 1/2 to 1 watt.
And Vishay CCF60 series.
I forgot to mentions, the resistors I'm replacing is not on the pcb board but the ones that are under the chassis.
One last thing Rayma, should I use metal resistor or carbon? And thanks a million.
I use metal film for everything, even the power supply. Just go with the Dale RN65 resistors.
They may be a little longer than the originals, though.
The 1k grid resistors and the 470k input resistors can be 1/2W, but I'd still use 1 W for the 10k, 6.8k, 22k.
Don't change the 15.6 ohm resistor.
What about tolerance, temperature and voltage rating. Do I have to wrry about those? Thanks.
No, the Dale RN65 resistors are excellent, and will work as well as anything else could in that amp.
Where can you find 1/2 watt resistors with the appropriate voltage rating? I have personally only ever seen suitable 1 watt resistors for tube use.
So I recommend that. Much easier to find. And works just fine, obviously.
I now use the Panasonic ECG which I get from DK -- the 1W devices are the size of a 1/2W carbon comp.
On the Dynaco Tube Audio Forum we have a link below on the parts layout (with a photo) of the original Dynaco PC-3 driver board ...
Dynaco PC-3 board parts layout
Bob Latino
Bob Latino
- Tubes / Valves
- Dynaco st 70 resistor
