dynaco st 70 c3
Awesome Schade strapping of the output tubes.
Triode emulation with full screen voltage! And
the OPT is wrapped into the local loop... There
are actually several more clever things going on
within this schematic.
Definitely one worthy of further study.
ST-70-C3 [DYNACO ST-70]
your absolutely right its not a dynaco!! but audio research calls it a st-70-c3 super modification kit for dynaco 70 .. that off the manual.. my question was if anyone had a clear picture of the layout of the component on the board?? THANKS..
ARC ST-70C3 kit
Hello
I built the amplifier on this page, or at least the amp showing in the botton view.
If you look closely, you will notice a regulator chip there for the first tube fillaments and a small bias trandformer next to the power transformer.
The original Dyna transformer ran the tubes at 450v B+
I changed the transformer for a lower voltage tranny, but 400ma versus 300ma for the original.
I had to add the bias transformer because the new transformer did not have a bias tap.
bob
http://www.arcdb.ws/ST70C3/ST70C3.html
