Dynaco PAS transformer breakdown
Anyone who knows which winding breaks, primary, 12V or HT? It is quite usual even if the 3 I recently found are OK.
Think SY mentinoned something about it long time ago.
If it is the primary my idea was to add a tiny 6+6V toroid.
I've found usually that the high voltage secondary shorts in these transformers, but I have only encountered a couple that were that way. I have also encountered one with an open primary. Obviously none of these issues can be worked around and the transformer has to be replaced. Replacements used to be readily available.
Hey,
Was not into finding a replacement. I had hoped it always was the primary. In that case the idea was, as I mentioned, to add a small 6 or 12V toroid while still running the original for HT.
Kevin, to bad you found that the secondary normally breaks🙁.
