Dynaco 416 power transformer specs
Greetings all.
Does anyone know or have access to; the specified values of the Secondary voltages of the original Dynaco 416 power transformer.
I will need to get 2 units made for 240v supply down here in Tasmania. I'm building two from scratch.
I've had no luck finding specifications (anywhere) and guessing the values may end up being expensive.
A point in the right direction would be very helpful.
Thanks in advance.
See this thread: https://www.diyaudio.com/community/threads/dynaco-st416-amplifier-schematic.53380/
if you do not want to pay manualslib , audiokarma, or servicemanuals.net. I don't
The opinion in that thread is that ST416 is similar to ST400.
The schematics that are available show one pair of output transistors for each channel. I have an advertisement that shows ST400 for sale in 1975. The state of the art in output transistors in 1972 IMHO was npn 2n5630,32,33,34 and pnp 2n6229,30,31. Vcesus 140 v were the max values, but they leaked 200 ma at those values.
8 ohms*200w^2 is 1600 so output voltage would have been 40 Vac. Thus by the 2* rule indicates rail voltages were 80. I find single output transistor pair pressed at 200 w/ch, Peavey used 2 pairs in the PV-4C. Peavey used 2 pairs 2n5630 at 75 w/ch in the M-2600, at +-42v. The rail caps in the dynaco were ???? my computer refused to download parts values from djp.com as unsecure. If dynaco was actually using +-80 rails they were really living dangerously with those parts and heatsinks. I'd use those cap values but expect lower rail voltages.
PV-4C had 80 v rail caps, so we may postulate transformer voltages of +-63 to 67.
As PV-4c has 2 power transformers for some stupid reason, I would go looking for a Crown xls-402 or DC300 to salvage the transformers out of. The xls-402 voltage is not listed but the DC-300 is +-60v.
You need double the voltamps of the transformer for a class AB amp, so you want at least 800 voltamps.
As much as I respect the ST-70 and PAS3 kits, dynaco's tendency to violate heatsink rules and soa rules (which were not invented in 1975) caused a certain disdain among users. of the transistor amps. Blown output transistors. You did not see ST-400 on stage at 1975 rock concerts. You did macintosh, and crown. The styling of the PV-4c is **** but it is a workhorse. IMHO I'd rebuild one of those or a crown xls-402 or xls-602 if I intended to use my system for any length of time at anything near 200 watts/channel. Besides the PA amps have DC protection built in. A ST-400 front panel is lovely, as is a crown DC300. Absolutely do not rebuild the DC on speaker capable DC300, however many rock bands used them in the day.
Rails are +/-75V, trafo is 53-0-53V, 750 VA. Common to the 400, 410, 416.
120-140V transistors we’re used, but they were series connected. Being only an EF2, with TIP drivers, it was far too easy to get the voltages between them unbalanced under load - and those drivers wouldn’t take much more than 100V. Using MJE1503x drivers instead helped these amps in almost every way.
It’s a nice transformer, heat sink and chassis to build upgraded amplifiers into. Caps were underrated at 75V so mine were toast when I got it. It’s the same transformer as the PL400 or Ampzilla, and a decent size heat sink, which can be drilled for more TO-3 transistors.
I had a 400, there are better sounding amplifiers of that power rating using more available and less fragile semiconductors if you’re going to build something. Bob Cordell’s Hafler upgrade ( on the dH 500) is a much better amplifier as is his bipolar amp.
The Audio Amateur 3/83 by Bill Rollins update of the stereo 400.
Transformer with least 2 x 50 VAC secondaries (55VAC will get you +/- 74VDC after the bridge rectifier )
So a 110 VAC transformer - with dual secondaries you could use a separate bridge rectifier for each polarity.
