dvd player repair
It seems fairly common that the caps in the power supplies go bad after a while.
I have a cheapie $40 DVD player that was fine for a month,then started skipping and freezing..
One of the electrolytics in the PSU was buldging!
Same with an Apex player I have here,power supply caps.
But I think it needs a cleaning also,it's still being kinda funky at times.
Replace the filter caps,and maybe add a bit more capacitance,if you like.
snortonnorton said:
i would just go diving, fishing, or plain relaxing at the nearest tiki bar on the beach.
man i'm so jealous of where you live.
You'll get no sympathy from me. Try living in Michigan. We're expecting 5-7 inches of snow overnight, and then I get to shovel it clear in the morning :bawling:
Regarding the original topic, it could be a fault in the power supply someplace as was mentioned, a laser problem, or the motor that spins the disc could be failing.
Is this a DVD changer or otherwise expensive player? I ask because these things are so cheap now it may not be worth the effort to try fixing. I know locally I can get a really nice progressive scan player for $40, and a cheapo model for half that.
