Dual Operational Amplifier Question?
I am with a problem in the ClassD repair.
This turned off the value of the component.
Is a Dual Operational Amplifier?
Package SOIC 8 Pin.
In component botton is values:
53288 and MALAY
Exist LT1220 DUAL in ONE?
Is Circuit....
Hi, lindomar
The answer is probably no! You should find another replacement fast opamp for this. eg, TLC082, LT1362 etc..
Was your circuit working? I saw you are getting the FB after the filter. However IRAUDamps get this before the filter inductor for analog sigma delta modulation.
I do not have an idea about the 53288 &Malay
