Ds18 6000watts
Attaching driver board for the above amp. The smd transistors marked DA and BA are bad. Can I replace them with BCX56 and 2SA1416S?
They look OK. If you have to order, the 2SB1260 and 2SD1898 are a complementary pair.
In the future, please include working (<< important) links to the datasheets for both the original parts and the subs you're asking about. Please also note which spec of the replacement concerns you as questionable.
