Driver board planet audio
Hello everyone, does anyone have any idea what kind of drive it is or how to remove the recine with a chemical?
HpT4jz8
1) are you certain your problem lies inside it?
2) IF so, best is to ask for a replacement module from factory.
3) for all practical means,consider Epoxy impervious to *all* chemicals.
The few nasty enough to attack/dissolve it (think red fuming Nitric acid mixed with 200 Voume hydrogen peroxide or hydrochloric acid) will absolutely destroy any electronic component inside.
4) a guy posted on a Guitar pedal Effects Forum his experience on "degooping" a "secret" pedal:
I was on a short trip to Iraq as an it consultant for the us airforce, and I brought that + some other guitar gear with me. I was studying the Reeza outside, as I was called on an urgent task and forgot it on the porch. When I came home, the hot, hot, hot mid-day sun had melted the remaining goop, the capacitors, the knobs, etc.
