doubts on twisted light
According to the BBC doubts are emerging about 'twisted light'. It is even being characterised as a physicist vs. engineer debate.
I have my doubts about it, as I find it difficult to imagine how the lowest orbital mode differs from normal circularly polarised radiation. However, one of the rebuttals contains a glaring error. A resistor connected to an N-mode antenna in a heat box will radiate only an Nth of its thermal power in each mode; the authors forget this and claim that N-mode antennas violate the 2nd Law and are therefore impossible. Their resistor could cool down without violating the 2nd Law by 'heating up' the previously empty N-2 radiation modes in the cavity. The resistor is transferring heat from a hot body (the cavity and the two normal radiation modes) to a cold 'body' (the other N-2 modes). They are on safer ground when they say that if N-mode was possible then black bodies would radiate more heat than has been measured - although I suppose it is possible that some suppression mechanism prevents this from normally happening. So their rebuttal contans a hole.
