Double up transformers for IGC
I’m looking to build my first amp, and after looking at the some of the passdiy stuff, I’ve decided to try something a bit simpler and do a gainclone.
Problem is I’ve already used up almost my entire budget on connectors, blackgate caps, and riken/caddock resistors.
And I still need a transformer, I have a few options that I can do for really cheap, I have a 8-0-8 tranny from a 400va APC ups, that I could use, but I was really hoping for more then the 22V that would give me. (although this will be run into 4ohm speakers)
I also can get my hands on some pretty cheap ($2) 24V 95va trannys, but they only have 2 secondary wires (not center tapped),
Could I link 2 of them up in series so that it was like a center tapped 48V transformer something like shown below?
Lesson: Don't blow the budget on trimmings and run out of cash for the meat. Meat and potatoes with old cheap parsley is better than good parsley with no meat.
As drawn, it might work, but balance could be unstable. And you end up with a 24VCT winding, good for about +/-17VDC. However I'm really not sure it will be stable.
The same two 24V transformers, with Primaries in Parallel and secondaries in series, would give a solid 48VCT, good for about +/-34VDC. However that is rather a lot for most chips and heatsinks.
$2 for 95VA is a very good deal. But you can find 24VCT transformers at surplus prices if you look around.
Single no center tap transformer
ok, so the 24V transformers didn't work out, but i got some 18V ones from this surplus place, two of em gives me about 52V DC
I hooked er up first thing this morning, and it ran great, at low volume, I'll be running this into 4ohm speakers though, and well, 52V is way to much for LM3875. After playing with the Overture_Design_Guide13.xls I found that 25V is more what I should be shooting for.
So without further ado I give you another wonderful drawing, I think this address my problem of not having a center tap on these cheap transformers I got. But I don’t know if you can parallel rectifiers.
And I’d love to just try this and not have to ask here, but I’m a bit worried about blowing stuff up, and after a couple of hours of searching I haven’t found much info on a setup like this. And tinkering with PSU designer II hasn’t gotten me anywhere either.
Thanks for al your help.
This is a great forum
blarg, :dead: looks like the Overture_Design_Guide13.xls uses the voltage for each rail, not the total voltage for it's calculations. So basically I'm dead on for voltage I wanted, about 50V total.
(Have I mentioned that this is my first amp? :clown: )
And I think I've covered that I'm using this design http://ampchipdiy.com/invertedLM3875_r2_1.gif. The only difference is that I have a 50K pot instead of the called for 100K, I don't know why I did that, but I seem to remember a few posts that said 50K would sound better.
Anyway, with the pot turned all the way down I still get quite a bit of volume (hooked up to old car 6x9 w/ output from a dvd player) and turning it up results in much squawking, and popping, what I think is the amp clipping. 😕 😕
Is there anything I’ve missed? Or suggestions anyone might have?
Could I have the pot hooked up wrong? Input and ground to the sides, and the center continuing on to the amp.
😕:bawling:
it will work, but you wouldn't get 48v. Instead, you will get 2x12v, as now the voltage on each primary will be halved. Also, the "ground" on the secondary wouldn't be stable, as someone else had pointed out.
I would parallel the primary instead. You wouldn't get 24x1.4v. Instead, more like 24vx1.1 - 1.2 (26-28v) under load.
Re: pots
uvodee said:
I use 25k pots (because i had them in my bin) seems to be working just fine..
I am at the end of the line with the voltage, 63 volts to be precise and 8 amps (toroid)
I hope the LM's last !
J-P
And are you able to get a full range of volume control from them?
That’s the problem I seem to be having :xeye:
And Millwood, thanks for your post, 🙂 it didn't take long for me to see the error in that first drawing. I've ended up with something more like this right now.
