Anybody have any ideas for this one? Basically I have a sonotube sub that I made that I've had it aiming up, however its very top heavy with it being a little in diameter, 6 feet tall with a 12" woofer at the very top and the ports/input terminals at the bottom. Anyhow, I had any idea, of using double sided screw/spike so I can aim the woofer down, but have enough clearance for the woofer to breath.
I think the woofer should couple a little bit better firing into the floor rather then the ceiling.
Anyway, I'm thinking of maybe gluing/welding something together, like wood screws to somethin on the other end.... any ideas?
A custom machine job would do the trick. A rod with a spike in one end and thread in the other....a hex on the middle.
Should not be too expensive to make. I made something like that a while ago to see what happened if i made my old sub downfire.
Magura 🙂
Magura 🙂
A spike would be too short. If your driver was that close to the floor, all you'd have is boom. So the answer is simple: go to the furniture legs section of your home store, buy some very short legs (or dowel or hardwood stock) and buy some double-ended screws. Thread one end into your new feet, the other end into the baffle. Make sure you do this in such a way that the cone can have full travel.
Magura said:A A rod with a spike in one end and thread in the other....a hex on the middle.
Hey ...read what have been posted already....this thread isnt too long to ask for that.
A rod....of any desireable lenght...with a spike in one end and thread in the other.
Magura🙂
Magura said:Hey ...read what have been posted already....this thread isnt too long to ask for that.
I read your post. I disagreed. 🙂
