double c core power transformers
Disabled Account
Joined 2002
Hello,
I have a pair of double c core transformers for tube gear. One brand new and one used in a TEST configuration. Power rating is 300VA. Multiple electrostratic screens. Weight nearly 5 kilogrammes a piece. I will add two free chokes if you are telling me what will be the future use or Black Gate 22mF 350 volt VK capacitors. Payment with paypal. Greeetings, Ed
All the technical info is in the photos
Do these Trafos have a secondary voltage? It might be useful to members.
Hello,
I thought the pictures are clear.
The primary side offera ar range to adapt for the voltages here in Europe.
The secundairy side has windings for tube rectifiers and / or signal tubes and two seperated high voltage windings with different current rating and different voltages.
Greetings, Eduard
Hello,
I can add two powder coated stainless steel chassis like the one in the pictures with an aluminium or brushed stainless steel topplate ( according to your design) for a little extra so you can mount things safely
Greetings, Eduard
Hello,
Greetings, Eduard
Apologies, I couldn't resolve them on my 'phone screen. Clear on the computer! 🙂
Hello,
The same company who did make this transformers for me 15/20 years ago made a simple EI transformer with a few taps, lower power rating. It cost me 185 euro. You cannot find the transformers i am selling for a good price. Greetings, Eduard
P.s in the attachment you can see a set up for a choke input power supply
