Don't you just hate it when you build a guitar amp, Run it for 2-3 hours, Get it seemingly working perfectly and then,
Loan it to a younger brother(age40) and it lasts under 45 minutes!
" I was playing, it sounded amazing, I had it running @ 7 on the clean channel, 8 on the master,(40-50W Amp)It just faded out sounding sort of distorted, Now nothing comes out"
To Be Continued:
trout
Edit, My brand new KT77 amp
To Be Continued:
trout
OK, how wierd is this? I just finished a new stereo SE amp. It uses any of the popular audio tubes. I played it for a few hours last night with 6L6's, it worked great. Tonight I put in a pair of Chinese KT-88's that I have used for at least 5 years, and cranked it up loud. After about 1 hour, 1 channel just faded away slowly. It lost some volume, then got distorted, and finally stopped making sound. It took at least 2 minutes to completely die. I put the 6L6's back in, everything is normal. One KT-88 is dead. After sitting around for another hour, the silvery getter is turning white. The tube sprang an air leak. There are no obvious cracks, but air got in.
I have seen the slow fading away symptoms caused by an open heater also. It only takes 10 to 30 seconds to die.
I Talked to him on the phone for about 30 minutes, The tubes all light, and a tiny bit of sound comes out the speaker, The unamplified guitar is louder.
These were all new JJ tubes, I know occasionally a new tube can die, but it never ceases to amaze me how he has this magic touch.
A couple years back, I started getting back into the whole amp thing simply because he gave me all his DOA's lol
He has very simple instructions when using my gear, DO NOT Touch ANYTHING.
So, I get the unit back tomorrow, He is about 1 hr away.
He was as impressed as I am with the sound of the new KT77's, I just hope they are not burnt.
Tomorrow tells the tale.
Gene
Gene
It has NOTHING to do with science or facts... Younger siblings OR children break ****. I buy 4 new remotes per year. They complain because the 27" Trinitron flat screen is upstairs...
They just don't get it!
Trout said:I Talked to him on the phone for about 30 minutes, The tubes all light, and a tiny bit of sound comes out the speaker, The unamplified guitar is louder.
Gene
Your brother wouldn't happen to be this guy:
Abilities
It is said that when Impmon appears, electronics temporarily go crazy.
http://en.wikipedia.org/wiki/Impmon
HAHA,, that was GREAT!!
Well, I have it back, Ran the old digital VM around it, Looks like theres some sort of problem, A failure of some type.
Something looks very very wrong with the preamp voltages, And B1-4 are suddenly very high?
Working Schematic
I did not get a chance to write down the initial voltages but they were for sure 400V and lower.(B1 thru B4) Almost like there is no load.
All voltages below with tubes installed, Speaker plugged in on 8 ohm selection, No input source( Jacks closed )
V1-3 12AX7 (JJ-ECC83)
V1
Pin 1- 181V
Pin 2- 0V
Pin 3- 2V
Pin 6- 164V
Pin 7- 0V
Pin 8- 1V
V2
Pin 1- 181V
Pin 2- 0
Pin 3- 2V
Pin 6- 273V
Pin 7- 180V
Pin 8- 182V
V3
Pin 1- 85V
Pin 2- 0V
Pin 3- 2V
Pin 6- 272V
Pin 7- 24V
Pin 8- 62V
KT77 X2
Pin 1- 0V
Pin 3- 423
Pin 4- 425
Pin 5- -44
PS
B1 440V
B2 429V
B3 338V
B4 285V
As weird as the 12AX7 pin voltages are, This might be a nightmare to figure out. I get sound out of the amp, SORT of, Its very low volume and distorted and sounds like a bad compression effects pedal.
Thing is, It was easily pushing out in excess of 30W output prior to leaving. For no less than 2 hours.
I'll get a bottom view picture posted in a bit. I need to clear some FTP space.
Trout
Pins 7 and 8 on V3 show some trouble (that's the driver isn't it?). Not sure where it is coming from but I would measure all resistances between V3 and its coupling caps on either side, and I would probably replace these coupling caps.
Then again maybe V3 is at fault.
Yep, V3 is the driver, I replaced all the tubes already with new ones, Pays to buy bulk sometimes.
Confirmed indeed these voltages are correct, well Not correct, but listed here correctly.
I got a bottom view picture
Bottom View And Top View
I would be surprised if its the caps or resistors, But anything is possible. The resistors are basically all 1W, All the film caps are 630V which is plenty over the needed ratings. Everything used was freshly ordered stock.
This was my first real attempt at an eyelet board type construction, Its the prototype for the turret boards I am planning to use on a few more.
Its looking more and more like a total nightmare now.
I did not put the board in with easy removal in mind, now its looking like I made a huge mistake not planning for serviceability
Very nice looking amp
I can't see a reason why there should be any DC on the driver's stage grid, and the Vg-k is suspect.
Gene, can you remeasure V3 1,2,3 again? And use a lower scale for pin 3 (more accurate). Stage 2 looks weird too, but stage one has some voltage or current "missing".
Hey lndm,
The V3 second stage phase splitter has equal voltages across the anode and cathode resistors... which is right. Do you suppose the funky grid reading might be because of the meter loading that grid leak bias arrangement?
EDIT: V3 NOT V4
EDIT: V3 NOT V4
lndm, actually, you would expect DC on that grid. Note the RC coupling and the 56k resistor that the driver is sitting on. But indeed, the Vgk is not correct. That's a nice clue.
Wups, you may need to measure Vgk on the driver directly because of the loading of the voltmeter.
OK,, Just replaced a few caps, Both .022 caps on master volume, And both .1 coupling caps.
I only picked up an insignificant difference increase.
Another oddity, Full treble control setting nearly kills the output like a switch. ( was fine before )
I lowered the bias voltage to 40V on the KT77's and did pick up a very tiny amount.
(Measured at the center post of the pot)
I checked every resistor that I could without the tubes in, of course several interact and will need lifted to measure properly.
I can find no evidence of anything over heated, no funny smell,and rechecked every joint.
The Only thing not checked besides a couple resistors are a few jumper wires on the bottom of the board which I can not see, But point to point continuity checks show correctly on those.
This has to be something strange.
Maybe a wire broken internally or a yet to be discovered dead cap or resistor.
Gene
Oh This is looking to be a late nighter lol
Pass the coffee
Edit: Running for requested voltages.
Gene
Gene,
Pull V3 and measure resistance from pin (socket) 3 to ground... should 1500 Ohm ish. Measure from pin 1 to your B3 point... 100K?
SY, lndm,
What would this tube do, first stage V3, if the grid were unconnected?
Reason I ask is plate to cathode is 83-85 volts... that puts his q-point to the left of the zero grid series on the load line. As if the tube were "saturated".
Open or shorted socket?
V1
Pin 1- 184V
Pin 2- 0V
Pin 3- 1.5
Pin 6- 162V
Pin 7- 0V
Pin 8- 1.2V
V2
Pin 1- 182V
Pin 2- 0
Pin 3- 1.5V
Pin 6- 287V
Pin 7- 182V
Pin 8- 183V
V3
Pin 1- 73V
Pin 2- 5.4V
Pin 3- 4.8V
Pin 6- 278V
Pin 7- 24V
Pin 8- 63V
Tube Pulled V3 Pin 3 to ground is 1501 ohm
Pin 1 to B3 is 99.5K
Pant Pant Pant, My work area is in the basement, My online PC is on the second floor, 16 steps from basement to 1st floor,16 Steps 1st to 2nd, I think that was trip number 87 since noon!! I need to run some cat 5 downstairs FAST!!! lol
Gene
Pin 1- 184V
Pin 2- 0V
Pin 3- 1.5
Pin 6- 162V
Pin 7- 0V
Pin 8- 1.2V
V2
Pin 1- 182V
Pin 2- 0
Pin 3- 1.5V
Pin 6- 287V
Pin 7- 182V
Pin 8- 183V
V3
Pin 1- 73V
Pin 2- 5.4V
Pin 3- 4.8V
Pin 6- 278V
Pin 7- 24V
Pin 8- 63V
Gene
Gene,
Your grid voltage on stage 1 of V3 is positive with respect to cathode. That means grid current is flowing and some positive voltage has crept into the V3 grid.
I'll bet the .1 cap between V2 and V3 has shorted...
There is about 180 across that cap...
Lift one end of the cap... measure its resistance... power on and let's see if we can get the V3 pin1 up to something reasonable like 150-200 volts.
- Tubes / Valves
- Don't you just hate it when
