hfa25pb60 by IR soft recovery diode 23ns, 25/10 Amps .I am planing to build(I hope I can??) rectifier from theese, does it hold aleph 5?? 🙄
Go for it.
First choice for many Aleph buliders.
There are two diodes in there, You have to use both of them in parallel.
two diodes?? as long I can remember there are 1 diode.. but I can mistake. I think I need 4 of them to build rectifier. here is the data-
http://www.schuro.de/Daten/IR/hfa25pb60.pdf
by the way 3.254EUR is good price? I am planing to buy bunch of theese 🙂
You are right, mixed this one up with a different type.
The price seems good, Richardson (www.rell.com, usually they have very good prices on IRF devices) calls 4$05 for quantities between 100 and 249.
wow. did I understand right- I need this devices also mix with something else??
it would be nice to know because tomorow I will fill order blank..
yap this sentence "You are right, mixed this one up with a different type." is double meaning 🙂
thanks for help.
by the way gladly to see that shotky diodes becomes more and more powerful/ 5 years ago I bet there was not 25-30 theese soft recovery diodes..
thanks for help.
- does this diode good for aleph?
